Brake light stays on
I did swap out my rear brake light - just as another step to make sure that it was the switch during troubleshooting, same problem - brake light was still stuck on no matter what bulb I used.
So - visited my dealership - $60 later, have the new switch installed. They *DO* go bad, this one took five years to go bad... but it *DID* go bad...
Just a FYI - on the 07 FLSTC - when you squeeze the brake handle, it relieves the pressure on the switch, which turns on the brake light (the button pops out) - and applies pressure against the master cylinder plunger. When you release your hand on the brake, it applies pressure on the switch (pushing the button in), turning the brake light off.
Also - all the switches do is essentially create a closed circuit. So, if you wanted to test the electrical line, you can short the line (when a switch goes bad, mostly they short *off*, but sometimes they will short *on*, which is why you see the brake lights on) by shorting the line, the brake light goes on, if you break the circuit, the light will go off. This is also to see if you have a short in the wire harness and its not the switch (yet another electrical troubleshooting step...)
Edit: I tested the switch with my ohm meter after I clipped it out - and it was stuck in the closed position, so current was passing through it. Bad switch... I've only seen a few switches like this go bad in twenty years, most of them break in the open position.
And get it done fast. The brake light staying on can melt your tail light.
Thanks guys.
Oh well, if I told her I was putting a "fix" on her bike instead of doing it the way the book says she'd be unhappy with me. Happy wife, happy life.
