Hi guys I have a problem with my brake light. I have a night train 2008 and the brake light flickers when accelerating. I changed the front brake lever to see if I could rectify the problem. I had this sort of problem before which the brake light would stay on and now changing the lever fix that problem and created an other. This is really bugging me can some one help please.
The lever wears out? Really? News to me. There is a possibility that your master cylinder is gummed up and not pushing the handle back to its home position into the switch.
Probably the switch. Make sure the little metal V clip is behind the switch and it is tight.
There can be inconsistencies in the levers so they can make it better or sometimes make it worse.
I had this issue and wound up using something like epoxy to "build up" the part on the break lever that touches the switch. A few test fits and some sanding and it's been good to go fore years. Some guys have actually put a screw into the switch button to give some adjustment.
HAd the same problem with our '05 Deluxe. Changed out everything (switch, spring, ...). It turned out to be a bad master cylinder. Was told this has been seen as an issue.
