Screwed up my clutch adjustment
Old Oct 7, 2011 | 05:27 PM
Bullbutch's Avatar
Bullbutch
Default Screwed up my clutch adjustment
My clutch felt a little weird yesterday on my way home so today after work I did a clutch pack adjustment that I have done before. Now the clutch isn't moving. It almost seems like the clutch cable is broken. At first after the adjustment I was pulling the clutch lever and I could hear and feel a snapping behind the derby cover. Now the clutch isn't doing anything. I am sick about this cuz i had rides planned for saturday and sunday. This a 2011 Cross Bones with 2984 miles on it.
Old Oct 7, 2011 | 05:31 PM
Stiggy's Avatar
Stiggy
You flipped the 3 ball ramp under the clutch actuation cover on the right hand side.
Old Oct 7, 2011 | 05:32 PM
soft 02's Avatar
soft 02
Take it to the dealer. Sounds like a broken cable and I would be supprized if you could break it by over adjusting it.
soft 02's Avatar
soft 02
Didnt think of that but sounds posible.
Old Oct 7, 2011 | 05:33 PM
Bullbutch's Avatar
Bullbutch
Is this something bad ? What do I do?
Old Oct 7, 2011 | 05:37 PM
soft 02's Avatar
soft 02
The 3 ball ramp thingy is under the first trans cover on the right side. If your ***** are stuck then you need to pull it off and if you snapped the cable you have to pull the cover anyways.
Old Oct 7, 2011 | 05:40 PM
soft 02's Avatar
soft 02
http://partsfinder.onlinemicrofiche....=13&A=585&B=17
Here's a break down.#12 and #26
Old Oct 7, 2011 | 05:42 PM
Bullbutch's Avatar
Bullbutch
I don't think the cable is snapped?
Stiggy's Avatar
Stiggy
Not bad at all...The cover that the cable attaches to has a ramp that when you pull on the cable, the ramp 'tries' to climb up itself but instead pushes the rod out towards the left. That's how a clutch disengages,
If you pulled it during the adjustment though, it went too far and 'flipped.'
Loosen the cable adjusters, pull the cover, ( you'll have to loosen the exhaust,) and put the ramp lever back down to about 6:00 O'clock. (Stretch the cable taught down there, in other words.)
Re-assemble, ( make sure the 3 ***** stay in their groove in the ramp,) then re-adjust your clutch pack, and then your cable in that order.
And remember: Never pull on the clutch lever DURING adjustment!
Old Oct 7, 2011 | 06:08 PM
FroggyFatBoy's Avatar
FroggyFatBoy
