Screwed up my clutch adjustment
Old Oct 7, 2011 | 06:11 PM
FroggyFatBoy's Avatar
FroggyFatBoy
Originally Posted by Stiggy
Not bad at all...The cover that the cable attaches to has a ramp that when you pull on the cable, the ramp 'tries' to climb up itself but instead pushes the rod out towards the left. That's how a clutch disengages,
If you pulled it during the adjustment though, it went too far and 'flipped.'
Loosen the cable adjusters, pull the cover, ( you'll have to loosen the exhaust,) and put the ramp lever back down to about 6:00 O'clock. (Stretch the cable taught down there, in other words.)
Re-assemble, ( make sure the 3 ***** stay in their groove in the ramp,) then re-adjust your clutch pack, and then your cable in that order.
And remember: Never pull on the clutch lever DURING adjustment!
thats some good info there.. i'll have to remember that..
Old Oct 10, 2011 | 02:02 PM
Bullbutch's Avatar
Bullbutch
You flipped the 3 ball ramp under the clutch actuation cover on the right hand side.
You were 100% right. She is all better now. Your a genius.
Old Oct 10, 2011 | 04:59 PM
oct1949's Avatar
oct1949
__________________________________________________ _________
Ur not the 1st to do it.
I've seen exactly the same problem and fix Posted in here at least a hundred times through the yrs I've been here.
Old Oct 10, 2011 | 05:18 PM
Gman in NC's Avatar
Gman in NC
I was going to take on this task tomorrow (while it's raining anyway). Great info guys. Thanks.
Old Oct 10, 2011 | 06:22 PM
gforrest2's Avatar
gforrest2
My question is why would an '11 with less than 3k miles need to be adjusted. Or is it just a "break in" adjustment?
Old Oct 11, 2011 | 02:54 PM
Gman in NC's Avatar
Gman in NC
Did mine today and remembered to not touch the hand lever if the 'basket' is loosened up. Everything went fine and I'll pass that info on for sure.
CZshooter
Mar 9, 2016 12:41 AM
RJHD
May 4, 2014 08:15 PM
Dangermouse
May 30, 2013 07:04 AM
bigdog bigdog
May 29, 2011 01:48 PM
Wally
Jun 5, 2010 08:00 AM
