N/T - Deuce rear wheel swap
Old Oct 11, 2011 | 12:38 AM
BrianG's Avatar
BrianG
Default N/T - Deuce rear wheel swap
I'd like to get just a bit more rubber on the back end of my 2003 Night Train which comes with a 16 X 3 OEM rear wheel.
I notice that the early Deuce came with a 17 X 4.5 OEM rear wheel.
Is the Deuce wheel going to swap into the Night Train without a lot of grief?
Old Oct 11, 2011 | 12:34 PM
Harley_Dude's Avatar
Harley_Dude
Change belt, pulley, spacers, caliper.
Old Oct 11, 2011 | 08:48 PM
HDnoob's Avatar
HDnoob
I have an early deuce wheel(17 x 4.5 w/ a 180/60/17 SE dunlop) on my 03 train. I didnt do it so I am not really sure what was invloved. I measured the belt and its 1 1/8". Not sure if thats the stock one or not. However, everything fits and there isnt anything I have noticed wrong with it. So it can be done. However I might have about a credit cards thickness of space between the tire and the belt guards.
Old Oct 11, 2011 | 10:39 PM
BrianG's Avatar
BrianG
Could you explain the need to replace the belt and pulley and caliper?
Do you mean that they are replaced with Deuce parts?
I get the probability that spaces could be different.
Old Oct 11, 2011 | 11:08 PM
story808's Avatar
story808
Why? I never like the way the Deuce wheel look, just me though???
My advise would be to save up your coin and buys some wheels you like instead... on my 05 I'm running a 18x4.25 and a metz 160 on the rear.
Old Oct 11, 2011 | 11:14 PM
DevilDogg's Avatar
DevilDogg
Well one thing with changing the belt and pulley to a narrower one is to allow for more clearance so the wheel doesn't rub
Old Oct 12, 2011 | 08:28 AM
Harley_Dude
Yep, narrower belt and pulley. Look at a Duece caliper the back has been shaved for clearance.
Old Oct 12, 2011 | 10:35 AM
tazman527's Avatar
tazman527
I have a 2009 Deluxe FLSTN. I am changeing out the rear wheel for a 2003 fatboy solid. With the baggs I run you can't see the rear wheel that well and I do almost all my ridding long distance. You can patch a tubless and get in, not a tube. Your stuck. So much for why. Now the thing is, in the shop manual it showes both spoke and solid wheels useing the same spacers. I am putting in new bearings 25mm and getting a new inner sleve/spacer. Is there anything ells that could cause a problem?
Old Oct 12, 2011 | 08:58 PM
BrianG's Avatar
BrianG
Point taken. Can anyone point me to a source of spoke wheels where I can get a 4.5" X 17" unit?
I prefer the 17" for the wide choice of tires.
jd8181
May 15, 2021 08:38 PM
eviltwin69
Sep 5, 2018 04:37 AM
Half-Fast Deuce
Jun 11, 2013 06:13 PM
rolfsharley
Wheels/Tires
May 14, 2011 04:36 PM
crossfire3006
Feb 8, 2009 06:51 PM
