New Fat Boy Brake Problem
Old Nov 8, 2011 | 07:38 PM
Bop49's Avatar
Bop49
Default New Fat Boy Brake Problem
One week old 2012 Fat Boy with 300 mi. Rear brake caliper is dragging and not releasing all the way. Cannot drive it this way without burning up the pads and rotor. Anything I can check or do or trailer it 25 mi. to dealer? Thanks.
Old Nov 8, 2011 | 08:38 PM
kylebru1's Avatar
kylebru1
ill be honest i have no idea, but i remember a while back on a farm i used to work on an old truck we had the breaks were dragging and we just took a flathead screw driver and carfully pried it away. i have no idea if that would work at all or not but if you could get it out enough to get it to the dealer with out trailering it. but i would def. have them take a look at it for sure. sorry i couldnt help more.
Old Nov 8, 2011 | 09:05 PM
Rakthi's Avatar
Rakthi
Aren't they supposed to come pick it up? It's a new bike, just call them and tell them your rear brake is dragging and you don't think it is safe to ride the 25 miles to the shop. You should have gotten a free 1 year HOG membership with the new bike. That includes free trailering in case of trouble.
Side note, how hard is the rear brake dragging? The rear on my bike been dragging from new. Not enough to block the wheel, but enough the rear doesn't spin freely when on the lift. Supposed to be normal. Haven't burned rear rotor or pads.
Old Nov 8, 2011 | 09:07 PM
RedNose44's Avatar
RedNose44
I have 600 miles on mine, and the outer pad is doing the same thing. I was told by the dealer that it was normal and would wear in. I am getting some brake dust on the rear wheel, but the rotor does not seem to be getting damaged. If mine is still dragging at the 1000 mile service I will press the dealer to do something.
Old Nov 8, 2011 | 09:09 PM
Other Sheep's Avatar
Other Sheep
Almost all the new ones will drag the brakes for awhile. Kind of a scuffing noise as you come to a stop. The noise will soon go away if that's what you're worried about. If it's dragging enough to bring you to a stop then you've got bigger problems.
Old Nov 8, 2011 | 11:58 PM
Bop49's Avatar
Bop49
Default Problem Found
The bottom of the inner brake pad came out of the slot it rests in the caliper. Took the caliper off and put it back in place. I have no idea what caused it. I do not see how it could come out unless it was not right from the factory. Will try it and see if it happens again.
Old Nov 9, 2011 | 04:59 AM
slove's Avatar
slove
I just purchased my Fatboy Low yesterday and the disc brakes do drag,the pads should seat in with miles. Also disc brakes to drag by design it is part of the self cleaning to keep the rotor dry and clean. I can't wait for spring as I live in Michigan and my new toy will be going into storage.
Old Nov 9, 2011 | 05:58 AM
Rakthi's Avatar
Rakthi
Bizarre, you are the 2nd one in ą2 weeks with this particular problem! Someone screwed up royally with the pre-delivery check of your bike!
Just for the record, I'd give the dealer a "courtesy call" and tell them they screwed up. Could have gotten you into some serious trouble!
Originally Posted by Firemed509
On Friday I was out for a ride and my rear brake on my 2010 Fatboy Lo made loud sound when I applied the brakes. I pulled over and it appeared that the inside brake pad was out of the caliper. At the time I thought I was lucky I was only a couple of miles away from a local dealership. ...
Here is link to thread: https://www.hdforums.com/forum/softa...ml#post8972858
ss27gogeta
May 6, 2018 01:26 PM
warprints
Oct 18, 2016 10:16 AM
Moose67
Oct 13, 2010 08:34 AM
terry rowland
EVO
Feb 26, 2010 08:57 AM
jwlehman
Apr 17, 2008 08:03 PM
