oil pumps
Old Nov 12, 2011 | 10:13 AM
dongorgon's Avatar
dongorgon
Default oil pumps
Can handle the stock oil pump handle 100/100 hp/tq + output ?. read info on modified spring pressure relief
Old Nov 12, 2011 | 10:35 AM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
yes the pump is no problem with higher torque/hp numbers. obviously higher oil pressure gets more oil to the moving parts, and improves circulation which helps keep temps down. I'm assuming you are reading of the Baisley spring. This is a very good product as the spring is made to a much higher quality that promotes smoother operation of oil pressure relief valve. and also allows for higher operating pressures. I install them in all my bike motors, cheap performance upgrade, (not hp upgrade, oil system, ,) would also recommend a better cam plate which has better oiling passages, some run ball brgs for cams. plus to finish it off, there are aftermarket oil pumps, but if you have a newer (09, newer) the factory oil pump is a very good unit
Old Nov 12, 2011 | 11:42 AM
dongorgon's Avatar
dongorgon
Ok that sounds like good insurance .how involved is the job for the spring up grade?
Old Nov 12, 2011 | 12:50 PM
harleycharlie1992
cam plate has to be out cant really get to the roll pin to remove the valve, (its just easier to do it with it out) knock out the roll pin at the bottom of the plate where the valve is, remove the spring and valve, make sure the valve is very free in the bore, replace it, install new spring, being careful on install the roll pin that you don't catch the spring, and reassemble the cam plate , easy!! down the road motors!!
Old Nov 12, 2011 | 02:21 PM
xwhyz1959's Avatar
xwhyz1959
I did mine with the cam plate still in no problem.
Pops98
Feb 1, 2015 05:05 PM
Guntoter
Feb 23, 2014 10:49 PM
John Mcintosh
Exhaust System Topics
Aug 25, 2010 02:20 PM
dog116929
Jul 8, 2009 12:42 PM
Mackatoni
Nov 15, 2008 12:33 AM
