Descrepency on HP
Old Dec 20, 2011 | 06:22 PM
RockerSE's Avatar
RockerSE
Pretty close to my numbers with a se257 cam. Dynos vary, I was hoping for the 100 hp mark but was in the mid 90s for hp and 110 ft/lbs on torque. Still I am very happy every time I twist the throttle.
Old Dec 20, 2011 | 06:26 PM
el chivito76's Avatar
el chivito76
was it measured sae or std. i believe there will be a difference in the dyno numbers then. if measured with std will be a little lower. thats what my tyner told me so take it for what it is.
Old Dec 20, 2011 | 06:31 PM
Sgt_Jim's Avatar
Sgt_Jim
NorCalFBLO's setup is almost identical to yours, except he's running the FatCat.. just for ***** and grins i'd ask him to email you his map, save yours to a computer, load his in to the PCV, and have it re-dyno'd..not tuned, just redynod and see if the power improves.. it'll probably run a bit more rich, but it's not a horrible thing.. and if it doesn't, just reload the other map back in to the PCV
Old Dec 20, 2011 | 06:43 PM
Fitz5526's Avatar
Fitz5526
3rd Gear
I'll have to check that out. Thanks.
Old Dec 20, 2011 | 06:44 PM
Fitz5526's Avatar
Fitz5526
3rd Gear
I'll find out. Thanks. What is SAE or STD?
Old Dec 20, 2011 | 06:46 PM
Fitz5526's Avatar
Fitz5526
3rd Gear
With my head work I should be at least where yours is at. Any way you can email me your map? If so fitz5526@aol.com If not thanks anyway for the info.
Old Dec 20, 2011 | 10:39 PM
BrianG's Avatar
BrianG
Rockford is almost 1000' elevation. You will lose some power due to that.
Also, I have discovered that there is some significant variation in OEM combustion chamber size from head to head so if you were unlucky enough larger ones you can lose something there, and if you didn't check and set deck height there is also some variance there that can lose you some more.
All little bits alright, but they can add up.
brnew
Engine Mechanical Topics
56
Sep 29, 2021 08:20 PM
Yo_Boss
39
Sep 24, 2016 05:36 AM
Gesjr6
22
Jun 18, 2016 10:12 AM
tattoo1964
Sep 24, 2010 07:22 PM
hdrk07_61
Exhaust System Topics
44
Apr 12, 2008 08:38 AM
