Cracked crankcase need replacement 2001 FatBoy
Old Jan 8, 2012 | 10:54 AM
SG1stingray's Avatar
SG1stingray
Angry Cracked crankcase need replacement 2001 FatBoy
Hi all this is what happened to me I went and tried to perform my own oil change and cracked the crankcase by trying to remove the nuts right below the crankcase. Is replacing the crankcase a fairly easy thing for an experienced Harley Mechanic to do. Please any info would be very helpful. Thanks.
Old Jan 8, 2012 | 01:38 PM
Blk and Chrome's Avatar
Blk and Chrome
Not all that easy to do, lots of work the whole engine has to be dissassembled. Bet it will cost some $$ for sure. Not sure why people do that and remove that plug then crank it in real tight, it's a tapered pipe thread. You arent the only one thats done that. I have heard that some peole have been sucessful using JB Weld to repair it. Good Luck
Old Jan 8, 2012 | 01:58 PM
pococj's Avatar
pococj
How big and how bad are the cracks? New cases are $$$$$, plus the labor to remove/rebuild/replace motor. If possible, I'd try anything and everything before replacing the cases, unless it was time to rebuild the engine.
Old Jan 8, 2012 | 02:00 PM
soft 02's Avatar
soft 02
How bad is the crack. Flush crank case and take it to a welding shop that has a tig.
Old Jan 8, 2012 | 02:54 PM
SG1stingray
I guess it not that bad of a crack that I could use JBWeld to try repairing it. I mean I really feel bad break it and my bike on has 1000miles I was wondering about what it would take to replace the crankcase and if it was worth doing that job.
Old Jan 8, 2012 | 02:58 PM
soft 02's Avatar
soft 02
I would say probably not worth it unless you need an excuse to put in a 120". If you JB weld i would drill the end of the crack to stop it from growing.
Old Jan 8, 2012 | 03:07 PM
PanHeadRich's Avatar
PanHeadRich
^^^ Agreed, stop drilling is a must ^^^
Old Jan 8, 2012 | 03:12 PM
jreichart's Avatar
jreichart
And to state the obvious.......
Get a manual. It'll save a bunch of $ and headache.
Old Jan 8, 2012 | 03:45 PM
SG1stingray
I guess I’m going to JBWeld once I’ll wet it dry without the oil for awhile
Old Jan 8, 2012 | 03:53 PM
soft 02's Avatar
soft 02
Be sure to remove the paint or the JB weld wont stick.
