Cracked crankcase need replacement 2001 FatBoy
Old Feb 17, 2012 | 12:50 PM
Jester750's Avatar
Jester750
You might as well put one of these in the spot where your old plug was.
Then you can drain the sump without cracking the cases again.
That might make you feel a little better about the money you're gonna spend on getting the cases welded and that you actually improved the thing by being able to drain all the oil out of the sump so it doesn't mix with the fresh new oil.
What a simple idea. Too bad Harley didn't think of it.
Here's the website:
http://www.jpcycles.com/product/423-968
Old Feb 17, 2012 | 02:31 PM
prldrm's Avatar
prldrm
This looks interesting, Jester. Everyone always talks about dirty oil mixing with new, but this is the first time I've seen this. Anyone put one of these in...or is it still risky with over tightening?
Here's the website:
Old Feb 17, 2012 | 07:02 PM
FroggyFatBoy's Avatar
FroggyFatBoy
another one for having it welded.
the plug with a plug shown above should be available at you local "real" auto parts store.. napa, or fishers.. or something like that.. the box store autozone and advance may not have it or know what you're even talking about.
Old Feb 18, 2012 | 10:26 AM
tmitchellof PG's Avatar
tmitchellof PG
I would go the welding route. Make sure you disconnect your battery before welding.
Tom
Old Feb 18, 2012 | 12:02 PM
str8jacket's Avatar
str8jacket
Originally Posted by Blk and Chrome
Not sure why people do that and remove that plug then crank it in real tight, it's a tapered pipe thread.
According to what I've read on this, the danger of cracking the case doesn't only come from over tightening them. From what I've read, you risk cracking the case just by breaking them loose. Any time you have steel tightly threaded into aluminum (tapered threads create extra force), and then expose it to the elements, you have a high potential for galvanic corrosion (an affect associated with joining dissimilar metals, particularly steel and aluminum). If you add salt to the equation (if you live/ride close to the ocean, or ride on roads that have been salted), the potential is MUCH higher. Galvanic corrosion can make the plug very difficult to break loose.
The OP said he cracked the case "by trying to remove the nuts right below the crankcase". That sounds to me like he cracked it breaking one of the plugs loose.
Old Feb 18, 2012 | 01:18 PM
Jester750's Avatar
Jester750
I ment to put this plug in to replace the old one after he has the repairs done.
I'm sure if you torque it in according to the Harley Shop Manual specs, it should work out fine.
vanmor
Shovelhead
May 8, 2016 08:16 PM
cop242
Exhaust System Topics
Sep 5, 2011 09:09 AM
Mogar
Mar 18, 2011 09:33 PM
richie t.
Sep 29, 2010 08:47 AM
alaskajeff
Apr 4, 2007 07:02 PM
