1999 night train speedo problems
Old Jan 11, 2012 | 08:15 AM
soldier of fortune's Avatar
soldier of fortune
Default 1999 night train speedo problems
i recently traded for my '99 night train and , love the bike, but since the time i have got it the speedo hasnt worked . i talked to the previous owner, and he asked me if i had washed the bike? and i said no, and was wondering what the heck washing your bike had to do with the speedo? anybody have any suggestions? everything else seems to work on the bike, except the speedo.
Old Jan 11, 2012 | 08:41 AM
RHillbilly's Avatar
RHillbilly
I think that runs off a sensor on trans could be bad or unhooked
Old Jan 11, 2012 | 09:11 AM
soldier of fortune
thanks for the info, i will look at it tonight
Old Jan 11, 2012 | 10:19 AM
story808's Avatar
story808
The reason he said that is cause the ignition switch turns it on and sometimes water gets in there and there is corrosion on the contacts.
Old Jan 11, 2012 | 04:10 PM
soldier of fortune
okay thanks, i will also check that out tonight .
Old Jan 15, 2012 | 01:20 PM
soldier of fortune
i pulled the dash assy off the tank ,pulled the connectors apart, and reconnected them, no worky, do the sensors go out in the transmission? is this a common problem? i know the bike is 13 years old, and where might be the best source for the sensor? harley or aftermarket?
Old Jan 20, 2012 | 06:57 PM
soldier of fortune
well i replaced the sensor in the trans and the speedometer still doesnt work any suggestions?
Old Jan 21, 2012 | 07:43 AM
cwsharp's Avatar
cwsharp
Instead of using the hit or miss parts upgrade method, I would suggest that you borrow one from a buddy that has a similar model and hook it up and see if it works. If it does, you need a new speedo. If it doesn't, start looking for shorts or lack of continuity. You need a wiring diagram and a test meter and you check to ground and end to end to make sure all the wires are good and only those that are supposed to be grounded are.
I took a slightly different approach and bought one on ebay. I figured I could resell it if that wasn't the problem, but I was pretty sure it was. If it's bad, buy the speedo/tach combo while you're at it. I wish I had but I was short on cash at the time.
C#
atrailblazer
Electrical/Lighting/Alarm
Jul 19, 2014 02:42 AM
rolfsharley
Mar 21, 2010 02:35 PM
bigsteve799
May 1, 2009 12:59 PM
jonnyrotton
Dec 22, 2007 02:55 AM
rockerhead
Oct 8, 2007 10:20 AM
