1999 Heritage dead short???
Old Jan 29, 2012 | 10:27 PM
egardner1970's Avatar
egardner1970
Stage II
Default 1999 Heritage dead short???
Hey guys, I just picked up a 1999 Heritage with what was supposed to be a dead battery. Well, I replaced the battery. It turned over a few licks very slowly. I let off the button. It turned over a couple of more times a couple of seconds apart AFTER I had let off the button! Then all went dead. No lights anywhere. At first I thought it was just compression (brand new Screaming Eagle motor) and a bad battery. However, when connected to a battery charger, it pegs the needle and the charger leads got hot. With the battery disconnected from the frame, it seems to charge fine. I took the right control apart to see if the switch burned a closed / short. Nothing. I haven't taken the right tank off yet to get to the harnesses to wring out pins yet though. I did find the #3 circuit breaker in bad shape and replaced. Any thoughts on where to begin?
Old Jan 30, 2012 | 09:46 AM
the blob's Avatar
the blob
I'd check Al grounds, then the main switch in the center
Of the dash.
Old Jan 30, 2012 | 11:30 AM
im's Avatar
im
Wires at central switch shorted or wire under tank shorted...or somehow the wires to starter motor are wacked.
Stingray702
Screamin Eagle CVO Models
Dec 8, 2018 08:39 PM
Raider Dana
Dec 15, 2011 06:58 AM
skannner
Aug 25, 2010 08:30 PM
sonicporno
Jan 11, 2008 10:30 PM
robking
Aug 21, 2007 12:28 PM
