Tail light wiring question
Old Feb 5, 2012 | 01:43 PM
jharanin's Avatar
jharanin
Default Tail light wiring question
I just done...well almost done with my project and the only concern I had was the clearance of the wire keeps i used. They are 3/8" diameter (fuel line straps with a 5/16" bolt hole). what Ineed is to have some thing thinner with a 5/6" bolt hole or something that 2 18 guage wires would fit inside and attach with double sided take to the inside of the fender...looking for some ideas from the great minds of the forum.
I've attached some pictures of what I'm currently using to give you an idea.
Any help is mucho appreciated
Attached Thumbnails Tail light wiring question-wiring-1.jpg   Tail light wiring question-wiring-2.jpg   Tail light wiring question-wiring-3.jpg
Old Feb 5, 2012 | 05:25 PM
RANGER73's Avatar
RANGER73
That looks like it will fit. What's your question?
Old Feb 5, 2012 | 06:11 PM
jharanin's Avatar
jharanin
It fits 3/8" is to wide and I can't find anything in a smaller diameter that will use 5/16 bolt (strut bolts are 5/16"). I'm looking for something narrow maybe using double faced tape...been looking online and have found a few things that may work but the description was very vague.
Old Feb 5, 2012 | 06:12 PM
jharanin's Avatar
jharanin
I've tried the set up in the photo and it rubs the tire.
Old Feb 5, 2012 | 08:56 PM
Badgerbob's Avatar
Badgerbob
The baggers use a rubber sleeve that has double sided tape for mounting to the fender inside. If this helps.
Old Feb 5, 2012 | 09:01 PM
jreichart's Avatar
jreichart
Try the depot or lowes, electrical section. They have flat zip tie anchors with double stick tape. They are about 1" x 1". You might need to trim it down, or heat it and mold to shape of the mounting point. But you stick it on, thread a zip tie through it, and strap in whatever wires you've got.
Might be lower profile, or you can put it wherever it is out of the way. Just make sure to clean attachment point well.
Old Feb 5, 2012 | 09:04 PM
BB06FLHX's Avatar
BB06FLHX
Get a section of fuel line and use that. Perfect fit.
Old Feb 6, 2012 | 04:12 AM
RICHIEMACK's Avatar
RICHIEMACK
Use a wire clip under the strut bolt,heat shrink it first.got them at home depot,in the nuts and bolts section ,hugs the fender close,fits like a washer.OR USE THE 3M DOUBLE STICK HANGERS,I USED THEM UNDER MY TANK TO RUN LED WIRES,BUT FOR WEATHER ID USE THE WIRE CLIPS
Old Feb 6, 2012 | 05:41 AM
jharanin's Avatar
jharanin
Thanks for the ideas fellas... Trying to find the parts you need is more of a PIA than actually doing the job...
Old Feb 6, 2012 | 09:19 AM
str8jacket's Avatar
str8jacket
I've used epoxy putty to hold wires in place under a fender and it worked great.
