To lift or not to lift?
Remove the console and let it hang down out of the way, remove the overflow tube from the upper-front part of the tank, and obviously remove the tank bolt from the front, and loosen the one in the rear.. take a measurement from the bottom of the overflow tube to the top of the backbone of the frame.. that's measurement 'A'..
okay, now lock your handlebars all the way to the left, then just pull the front of the tank up until the tank hits the turn signals.. remeasure from the bottom of the overflow tube to the top of the frame.. that's measurement B
if B - A is greater than 1.5", you can do the 1.5" lift just fine.. with the streetslammers installed, my measurement was like 1.6", and i was right, with the 1.5" lift installed, I have roughly a tenth of an inch between the bottom of the turnsignal and the top of the tank..and fully locked to the left, that's plenty of room..the right side has more room because of the throttle cables hitting before the turn signals
