My fender hole solution...
I pulled all of the adhesive material off the back of it, and then hollowed out the underside with a dremel so that the edges set down closer to the fender. Got some adhesive magnet stuff from the home store, cut it into shape and stuck it onto the back, and there it is.
The magnet stuff doesn't seem to be holding it very securely, so we'll see whether it flies off on the freeway. I like the solo look, but want to be able to quickly switch back to the pillion if need be.
I could just throw a chrome acorn on there, with the help of some 1/4-20 rod and some adhesive to hold it in the acorn, but then you still have the bit of hardware underneath it - that black plastic ring, and it protrudes a bit.
Has anyone else come up with any good ways to trim this out?
The dealer gave me a little black plastic trim cap, but it would require removing that hardware, and then it would snap right into the hole. that would be a lot cleaner.
Here's some links I've found:
Flames
Gold Live to Ride
Willie G. Skull Collection
Flames
Gold Live to Ride
