140 Series Front Tire
Old Sep 14, 2018 | 11:19 AM
barri's Avatar
barri
Stage III
Originally Posted by olongapo1
Experimented recently and mounted a 140 series tire on the front of my Train. Utilized a wheel off an 02 Heritage that I disassembled and powder coated. The wheel/tire combination bolted up correctly and is perfectly aligned. I like the "Old School" Bobber-Bomber look but have encountered some adverse handling characteristics.
Straight line, down the road riding puts a smile on my face. No wondering in groves or ruts. Feels like a tank. Maneuvering the bike through turns takes a little more effort which I expected however there's a point during sharp turns (both left and right) that the rear wheel feels like it's going to break loose. Scarry!
I'm running a 150 series tire in the rear and the bike is lowered 1 inch in the rear. Going to lower it another inch to see if that will compensate for the erratic handling.
Hi, there, new in this forum. Have just signed up when i have seen your front tires. Which rim diameter were you running in that time, Olongapo?
Old Sep 14, 2018 | 12:23 PM
soldierbot's Avatar
soldierbot
I run a 150 on the bike and go with 130 up front. I have tried a 140s up front but I hate it....less nimble in traffic and the twisties.
Old Sep 14, 2018 | 12:56 PM
XRX's Avatar
XRX
You're in the PI? I have friends there.
It sounds like you're getting lost on set-up issues. Let's see if we can get you pointed back in the right direction.
The wider tire, all things being equal, is going to make it handle even more sluggishly than it did before putting the wider tire on.
Swapping front tires will not reduce the rear tire traction.
Lowering it, especially in the rear, is the wrong direction- that's just gonna slack-out the front end geometry even more, making it handle even more sluggishly, and it's also going to reduce your cornering clearance, on a motorcycle that already has very little cornering clearance.
Old Sep 14, 2018 | 01:43 PM
barri's Avatar
barri
Stage III
130 in a 16" rim?
Old Sep 14, 2018 | 03:35 PM
soldierbot's Avatar
soldierbot
Originally Posted by barri
130 in a 16" rim?
No sorry...running 18s on the bike.
Old Feb 4, 2019 | 10:57 AM
barri's Avatar
barri
Stage III
Hi, mate; which rim diameter are you using in the front? thanks
travalab
Aug 5, 2018 09:20 AM
sparkybr74mr
Dec 5, 2016 05:28 PM
springr
May 15, 2014 04:59 PM
gilmour68
Jun 26, 2012 10:09 PM
Dragonsoni
Nov 19, 2007 03:59 PM
