Blacking out bolts
Old Mar 2, 2012 | 11:16 AM
Misbehaven's Avatar
Misbehaven
Originally Posted by theidbreder
Harleyfiremedic,
+1 that looks good and the look that I am goin for. I just wasn't sure if it would be easier to swap bolts or paint. Thanks
Problem with swapping bolts is that there are not any black ones I could find other then the black phosphate coated ones that will rust out in no time at all. I guess removing the bolts, spray painting them then touching up after re-installing might be the best route.
Old Mar 2, 2012 | 11:53 AM
Brutus01's Avatar
Brutus01
Originally Posted by Milty
Harleyfiremedic,
That looks good man. Did you take them out to paint then touch them up after?
He brushed them so my suggestion and what I may do is just loosen the bolts so that they back away from the other parts slightly then paint and let dry before tightening and touching up.
Old Mar 2, 2012 | 12:01 PM
Joker65's Avatar
Joker65
I use 1st Shot or 1-shot.... The outdoor sign paint used by pin-stripe artists. It's very durable paint that lasts forever!
Sorry about the name.... But it is great paint!
Old Mar 2, 2012 | 12:20 PM
jreichart's Avatar
jreichart
Originally Posted by harleyfiremedic
Did all the bolts that I wanted to black out with Testors Model paint. The Gloss and the Flat are really close matches for the HD Gloss and Denim black. It has held up very well and if I had to work on the bolts they touch up very easy. Less than a few bucks for the paint, brush and cleaner.
Here is a pic of the fender strut bolts on my Lo.
that reflector just jumps out and smacks ya in the face now doesn't it!
Bolts look good though! Might have to get off my *** and do mine one of these days.
Old Mar 2, 2012 | 01:07 PM
imboden's Avatar
imboden
Originally Posted by Misbehaven
You can us a method that was used years ago on the Panheads to make the bolts black. They used to parkerize them to a black or dark grey finish. You can get kits and do it you self for around 20-30 bucks.
No offense to anybody, but I would personally stay away from home parkerizing.
It deals with hazardous chemicals and heat! Plus, if it's your first time doing it, it usually doesn't turn our very well.
I re-built a few knuckleheads and a 1951 panhead a few years ago, and the stuff that you could buy parkerized compared to anything somebody did at home was way way better.
It also looks kinda dark grey and dirty.
Wish I had a better picture, but the rear axle and the service stand bolts are parkerized.
Old Mar 2, 2012 | 05:35 PM
poppavein's Avatar
poppavein
How about powdercoating? I'm fixin' to try my hand at powdercoating parts on my Blackline, and bolts would be a good first project.
Got the Eastwood gun and powder, just bought a toaster oven and plan on making the toaster oven box into a spray booth ...
Old Mar 2, 2012 | 05:40 PM
harleyfiremedic's Avatar
harleyfiremedic
Most of the bolts I just loosened and them painted. Once dry tighten carefully and touch up if needed. There are a few that were just a seas to remove and paint off the bike. Sorry I don't remember which ones I did which way.
Thanks for all the nice words on the look. And the reflector is required to get an inspection sticker and they seem to be very tight on that here in MA
Harleyfiremedic,
Old Mar 2, 2012 | 09:06 PM
BB06FLHX's Avatar
BB06FLHX
Harleyfiremedic, grab some black reflective tape and cover the reflector. Same result.
Or try another inspection station. I know lots of bikes (mine included) with no reflectors and pass our yearly inspection no problems.
BTW I'm from MA as well.
Old Mar 3, 2012 | 03:29 AM
jreichart's Avatar
jreichart
I put some black reflective pinstripe on mine. Front downtubes and swingarm. Blends right into the frame and lights up bright white in direct light.
flhxs103
Mar 23, 2016 05:00 PM
somorkc
May 30, 2015 08:07 AM
jrobinson424
Feb 15, 2012 07:58 AM
BayBones
Feb 1, 2011 05:26 PM
toastman
Feb 10, 2010 09:54 AM
