Brake and shifter not wide enough, recommendations?
Old Mar 12, 2012 | 08:43 AM
G9803's Avatar
G9803
Default Brake and shifter not wide enough, recommendations?
I just picked up an 04 Softail, I noticed when riding yesterday my knee was hitting off of the external K&N air filter and I was having a hard time reaching the brakes. I had to turn my ankle in and try to get a hold of the brake. Also noticed the shifter was a bit wide and required a similar reach.
Can anyone recommend an extension or a way to go about and make these easier to reach, the bike currently has the "zombie/Skull" theme going on (skulls). Would like to keep the same theme if I have to replace the current ones.
Thanks!
Old Mar 12, 2012 | 09:38 AM
Jester750's Avatar
Jester750
Kuryakyn makes some:
http://motorcycle-accessories.cruise...m_source=yahoo
Floorboard extensions:
http://www.harleygoodies.com/
Old Mar 12, 2012 | 10:10 AM
Joker_Hal's Avatar
Joker_Hal
I'm a bit on the short side, only 5-6 and had a problem with getting to the brake also. The air filter keep getting in the way. I took the bike to a custom shop, they took a couple measurements and moves the brake peddle out about 2 inches so it's not behind the air filter any more. Looking at the work, I can't really tell any thing was done, but it made a world of difference.
Looking at the links Jester gave, some moves the peddle forward, others make the peddle an inch wider, I had mine moved 2 inches to the right. Depending on what you were looking for, your covered either way.
Old Mar 12, 2012 | 10:16 AM
Hogpro's Avatar
Hogpro
Former Sponsor
Use passenger peg mounts, cut off the stock pedal and drill a hole in the brake arm. Get soem longer pegs.
Old Mar 12, 2012 | 10:28 AM
cherrick's Avatar
cherrick
Check this forum's member goodies for sale. I think you can get to the list from the home page.
I bought an extension kit designed by one of the forum members that became so popular he made it into a kit and now sells it via the forum pages.
Old Mar 12, 2012 | 11:38 AM
G9803's Avatar
G9803
Thanks Joker, my air filter comes out to a 90 degree bend and has the filter with the Screaming eagle cover on it (cone shaped filter). I'm fairly new to HD, so excuse my terrible references. I just need the brake lever to extend out more, since I have to angle my foot funny to get around the air filter.
Hogpro, thanks, I'll check it out.
As far as the forum members page, I never saw those, I'll have to check those out.
Old Mar 12, 2012 | 06:41 PM
G9803's Avatar
G9803
http://www.cruisercustomizing.com/2-...h/part/KY-8041
Does this look right? Just want the brake pad and shifter to sit out another 1/2-1" so I don't have to twist my ankle to reach either or. Thanks all.
Old Mar 12, 2012 | 09:29 PM
LaidInk's Avatar
LaidInk
From what I'm understanding, you are wanting an extended shift peg and extended brake pedal pad, there are many companies making these. Try a google search for both of those and see if you can find anything that will flow with the skull/zombie theme, you might not get exactly skulls but something that can compliment them.
Old Mar 13, 2012 | 05:18 AM
G9803's Avatar
G9803
Thanks laid, just need the pedals to stick out more
(wider). I have a hard time reaching them since the intakes in the way. I thought the link above would be what I needed. Not to worried about getting the theme dead on, just want a more comfortable ride where I can reach each pedal.
TheGoldy
11
Oct 28, 2017 06:43 PM
ultraclassic53
Mar 19, 2015 09:56 PM
Daddyburns
Jun 30, 2010 07:34 PM
ColoradoBill
Apr 2, 2010 12:11 PM
Garemlin
Aug 21, 2008 08:49 AM
