Coil and Horn relocated
Old Mar 12, 2012 | 10:52 AM
Fierofly's Avatar
Fierofly
Default Coil and Horn relocated
Used the stock parts. Removed seat post and cut off coil mount. Also cut off the horn mount on the top motor mount and bolted the coil mount to the motor mount. Swapped the frt and rear coil wires at the connector so I could mount the coil upside down after lenthing the wires about 12". Removed horn and replaced with a sporty horn to the front, had to lenthin the wires 6". had to use an old plug wire off an astro van V6 till the new 7" rocker wires get here (orange Taylors). Took about 4hrs cause I'd measure 3 times and cut once.
Old Mar 12, 2012 | 10:56 AM
Sgt_Jim's Avatar
Sgt_Jim
not bad.. i just did that too (obviously since we're both in the Lo Owners thread).. are you going to cross your wires since you mounted the coil up-side-down? or did you change the C/D wires when you did the extensions?
Old Mar 12, 2012 | 12:55 PM
Fierofly's Avatar
Fierofly
I swaped the C&D wires in the connector. look in the maint. Manual and it tells how to get the connector apart.
Old Mar 12, 2012 | 05:31 PM
1980FLHShovel's Avatar
1980FLHShovel
Nice job!!! Did you have to pull the tank to get the motor mount off or could you get to all the bolts with it on????
Old Mar 12, 2012 | 05:39 PM
soft 02's Avatar
soft 02
Sweet. Love this mod. Nice to get rid of that post.
Attached Thumbnails Coil and Horn relocated-img_0202.jpg   Coil and Horn relocated-img_0203.jpg   Coil and Horn relocated-img_0204.jpg   Coil and Horn relocated-img_0205.jpg   Coil and Horn relocated-img_0206.jpg
Old Mar 12, 2012 | 07:11 PM
Fierofly's Avatar
Fierofly
Wish I would have seen this first, would have saved me alot of design time. I left a little more of the coil mount on and bolted it to the motor mount after about 3 different cuts and alot of trial and error, making sure not to take too much off. I should have taken some inprocess pictures.
You got any installed pictures? curious how close you put to the tank?
Old Mar 12, 2012 | 07:17 PM
DyNaBoB's Avatar
DyNaBoB
nice job, i did mine last year, i get compliments on it all the time
Old Mar 12, 2012 | 07:37 PM
Misbehaven's Avatar
Misbehaven
I did mine a couple weeks ago. I like how it looks and I like the added air space around the rear cylinder after the seat post is removed.
Old Mar 12, 2012 | 08:26 PM
soft 02's Avatar
soft 02
To each there own. I wanted mine high and wires going down.
Attached Thumbnails Coil and Horn relocated-content-_media_external_images_media_383.jpg   Coil and Horn relocated-content-_media_external_images_media_384.jpg
Old Mar 19, 2012 | 04:55 PM
Fierofly's Avatar
Fierofly
Got the new wires on today, Taylor Thundervolts 8". Had trouble with the temporary wire I used on the frt cylinder. The knock Ion sensing wouldn't detect knocks on the Frt while tuning with the Power Vision. Can't ride till tomarrow so won't know if I'll have the same problem with these new wires.
