DECEL pops getting worse...
Old Mar 29, 2012 | 10:29 AM
  #61
ChromeJunkie's Avatar
ChromeJunkie
Originally Posted by Brancajd
any chance I can get a copy of your current map and give that a try before I go the dyno route?
I use my iPhone for my Internet source now, so if anyone can tell me how I can download it to my phone I will be happy to.
Old Mar 29, 2012 | 11:09 AM
  #62
Benway's Avatar
Benway
Usually, just hold down a finger on the image until a "save image" dialog pops up. Dumps it in your photos. You can also (as a last resort) hold down power button and home button to get a screen cap. Dumps it in your photos.
  #63
Brancajd's Avatar
Brancajd
Thanks, I appreciate it. If you have a laptop, you can hook it up to your bike and download it off the power commander. Once on the laptop, you can connect the iPhone and copy the file to it.
Old Mar 29, 2012 | 11:13 AM
  #64
Benway's Avatar
Benway
Originally Posted by oct1949
re-read through here again and wondering.
Are U running with or without Baffles in Ur pipes.??
Interestingly enough, I was getting quite a lot of decel poping (to the point of annoyance). Had the straight cheese-grater baffles. Put in a set of the quiet baffles in the V&Hs last night and took her out for a run (back roads and highway). Narry a single pop! Also no longer needed ear plugs. Still deep and throaty, just no longer shattering windows in the neighborhood.
Old Mar 29, 2012 | 02:02 PM
  #65
Brancajd's Avatar
Brancajd
hmm...if you're able to bring up the map using the pc software from a laptop, you can possibly take screen captures using the camera setting on the phone. I would need pictures for fuel table 1, fuel table 2, ignition table 1 ignition table 2. OR, if pull the map up from a laptop/desktop, you can save it, then send it in an email. If it's too much hassle for ya, don't worry about it.
Old Mar 29, 2012 | 02:06 PM
  #66
Brancajd's Avatar
Brancajd
it has baffles in it...not sure which ones. Most likely the louder ones.
Old Apr 3, 2012 | 10:26 AM
  #67
Brancajd's Avatar
Brancajd
Okay, been working with an R&D Technician from Dynojet via email regarding my issue. He had me try a few things but unfortunately, they didn't work. Despite my configuration, he then had me try map #805-017 (2001 model, Vance & Hines Big Shots (with baffles) with stock ECU and Screamin Eagle air filter). I did, with no luck. I then, promoted the map to advanced, and in both fuel tables, in the 0 and 2 columns from 1750 rpm on up (6500rpm), I added +25% fuel. I rode the bike this morning to work...no decel popping! I'm going to tinker with each fuel table and decrease the +25% amount in small increments until it starts to pop again, then add to it from there to dial it in. I'll keep you all updated.
Old Apr 3, 2012 | 06:34 PM
  #68
Brancajd's Avatar
Brancajd
On second thought..I'm going to leave well enough alone...
Pastoral1
General Topics/Tech Tips
Aug 25, 2018 04:46 AM
RLE
Jan 1, 2012 08:50 AM
eddieape81
May 9, 2009 11:10 AM
ltford2003
Feb 28, 2007 06:17 PM
Papamte
Sep 28, 2005 10:02 AM
