More capacity battery
Old Mar 28, 2012 | 03:41 PM
jnorbros1's Avatar
jnorbros1
Default More capacity battery
My 2005 cvo fatboy has from the beginning had a hard time turning over after sitting for a long period of time, cold or hot. When it's hot it really has to groan to get going; it's a little scary if it is going to turnover or not. So far it hasn't let me down. Since it is now going on 7 years , a new battery would be a good idea. Does anyone know where you can get a battery for this fatty that has more stuff than oem? Thanks in advance ....joe
Old Mar 28, 2012 | 03:47 PM
rrambo's Avatar
rrambo
People may disagree, but just a new stock HD battery should work fine as long as you keep it on a battery tender.
Old Mar 28, 2012 | 03:49 PM
soft 02's Avatar
soft 02
You could go to a Lithium battery.
http://www.batterystuff.com/batterie...davidson/2005/
Old Mar 28, 2012 | 04:11 PM
Tampa Fatboy's Avatar
Tampa Fatboy
You could also check the battery connections to see ya got a tite connection. Seen loose too many times. It's not like ya have ahigh compression engine that wasnt set up correctly with the start gear.
Old Mar 28, 2012 | 05:19 PM
TheTroupe's Avatar
TheTroupe
IF you want bragging right and pore grunt go for the Lithium.
http://www.shoraipower.com/p-206-lfx24l3-bs12.aspx
But Tampa Fatboy is right, the OEM battery with good connection and a battery tender should do you just fine.
Old Mar 28, 2012 | 05:21 PM
Hogpro's Avatar
Hogpro
Former Sponsor
Since you have the 110 motor that type of groan is expected. It's takes a bit more to crank that motor over.
Old Mar 30, 2012 | 07:43 PM
The88Beast04's Avatar
The88Beast04
7 years, yea time for a new battery, plain and simple.
Old Mar 31, 2012 | 09:26 AM
oct1949's Avatar
oct1949
Just put a new one in the bike this week. Org Batt Almost 5yrs old to the day.
I bought this one from Battery Plus.. it has 310 vs HD's 260 CCA's..
http://www.batteriesplus.com/product...7-to-2010.aspx
It was on sale plus they gave me the OLD mans discount, ended up $91.44 out the door. with 1 Yr warranty. They also have one with a 2 yrs warranty but they didn't have one that fit my bike in stock. Think it was $15 more. Both are AGM's.
The HD battery was $129.95 before my 15% discount with only 6 months warranty, also its a 100 miles round trip to get it.
The Batt + store is two blocks away. Saved another $30 in gas.
Anyway just thought I'd try one for Batt +.
Ur CVO may have a totally diff battery in it, ??? if it lasted 7 yrs it sure was a good one.
Also I put the tender on mine if it sat any longer than 4-5 days and during winter storage.
Mach1crazy
Feb 13, 2016 01:20 PM
casca
May 15, 2012 10:53 PM
Texas Tim
Feb 27, 2010 02:26 AM
abw121
EVO
Sep 20, 2008 05:27 PM
Sally88
Jul 5, 2007 04:20 PM
