96 Motor Advice For Upgrading
Old Apr 6, 2012 | 12:24 PM
CaptJohnny's Avatar
CaptJohnny
Default 96 Motor Advice For Upgrading
So I ended up having my motor completely detonate on me last fall at 2400 miles. Sucked obviously but more importantly was although it happened while riding in a tight group at 85 with traffic on both sides, I was completely fine and never went down. The more people I show the photos to, the more people tell me I am damn lucky she didn't completely lock up on me. Definitely had an angel because 30 seconds before that happened my helmet strap came loose on me which would have really been an issue.
I pulled the clutch as soon as I felt the bang, shook the whole bike, smoke coming from the air cleaner and out from under the seat, I had the clutch pulled and fell back from the pack, coasting onto the shoulder.
Harley covered the motor no questions asked, crate motor, and it was replaced by my dealer without issue.
When I bought the bike new I had stage 1 done immediately and went for a Dyno at 500 miles. I also added the screaming eagle race tuner per suggestion of dealer, although I still have not a clue what it actually does.
So now I have 1500 miles on the new motor, I have Stage 1, VH True Duals, Air Cleaner, and Race Tuner... that is the extent of my performance upgrades...
I am going to do a 107" upgrade this coming winter, basically my question is what to do until then. I do notice a difference in this motor, I feel as if it doesn't pull quite as hard as the last one after the dyno.... maybe my imagination.
My main question is whether or not I need a fuel management system... the more I read the more confused I get as to what that actually is... does this 500 dollar screaming eagle tuner serve any purpose whatsoever?
Thanks in advance for the advice.
Old Apr 6, 2012 | 02:38 PM
TheTroupe's Avatar
TheTroupe
Race Tuner is your fuel management system.
Old Apr 6, 2012 | 02:42 PM
Tampa Fatboy's Avatar
Tampa Fatboy
I'm just different I guess, pull the engine drop it off local machine shop guru. Use to be dood down called Don Cruz that take a shovelhead and blow ya mind. Now days still folks just like him. Course ya spend tha $$$ at HD or not. Just my two cents.
Old Apr 6, 2012 | 02:56 PM
Guy49's Avatar
Guy49
Contact Scott at Hillside. There in Munnsville,NY. Best Motor guys around. They will steer you straight and do some great work.
Old Apr 6, 2012 | 04:30 PM
oct1949's Avatar
oct1949
How about a little MORE info on what the Holly bat chit happen to the ORG rear jug....
I can't even imagine what the heck happened to do that to the piston.?????
Old Apr 7, 2012 | 05:48 AM
FroggyFatBoy's Avatar
FroggyFatBoy
with no marks in the piston top from valves or detonation, it looks like excessive heat to me.
Old Apr 7, 2012 | 10:19 AM
tunaman's Avatar
tunaman
WOW - that sucks!
I agree - give Scott a call at Hillside... you'll be very happy you did. They have a custom Wiseco piston for their 107" kit, and can do your build to your preferences from mild to wild. They did my top end work recently from afar, and I am extremely pleased with everything.
You need a tuning device once you go beyond basic 'stage 1' mods - SERT (Screaming Eagle Race Tuner) is the one that HD uses most, but someone familiar with tuning EFI can also use the software to modify their own settings. The tuning device (SERT, TTS, etc.) is an interface to allow advanced adjustments to your ECM for many of the settings - AFR (air-fuel ratio), timing, etc.
Best bet is to talk with your builder, have them assemble your engine to fit your needs, get the tuning device they are most comfortable with, and let them dyno tune your new build. Hillside can take care of that for you, and you will be most happy with the results.
Good luck!
Roger
Old Apr 7, 2012 | 12:47 PM
tbonetony06's Avatar
tbonetony06
Luck? That does not even begin to describe it! You had the good Lord himself riding with you that day! As for the best thing you can do with a new 107" build or any build?? Head work. I have said it before, say it again. Head work is by far the best mod anyone can do for thier bikes. Its also there and done for any future mods you do too. There is no way I would take a motor down and not do the head work while it was down.
Old Apr 7, 2012 | 03:39 PM
oct1949's Avatar
oct1949
YEAH,, with the 107 U'll need the sert even more so than just the stg1 mods.
It tunes U motor in about any way one can be tuned in the right dyno tuner.. IMO I like it because its not piggy back and if U do all Ur mods at one and then tune it Ur good till U make more major mods..
Had mine for 5yrs and haven't touched it since the org tune.
nomad billy
Engine Mechanical Topics
15
Jan 20, 2016 10:13 PM
bighatlaw
Screamin Eagle CVO Models
11
Sep 8, 2015 07:17 PM
hapbob
2014-2024 Touring Models
35
Jul 9, 2014 02:32 PM
Sean Dempsey
Jun 15, 2009 01:10 PM
hubble
Apr 26, 2007 05:20 PM
