My Slim exhaust
Old Apr 7, 2012 | 08:36 PM
beast 10's Avatar
beast 10
Default My Slim exhaust
So I put a vance & hines big radius exhaust on my slim today,I took it out for a spin and it ran fine so when I got back from a little 5 mile trip I let the bike cool down and pulled a plug and it was a bit white indicating that it's running a bit lean so I'm guessing that I'm gonna need to get a tuner. I did not believe the service department hype about getting a tuner with only an exhaust but I guess its true, so how much can I safely ride my bike in 70 degree weather until the tuner comes in ? Or should I keep it parked until I get one?
Old Apr 7, 2012 | 09:51 PM
NC D'LUXE's Avatar
NC D'LUXE
Ok, what the heck I'll bite.
How did the bike run?
What did the plugs look like before you went for your very short ride?
During this very short ride, was there anything different that you noticed before you put the pipes on, decel popping etc?
And by the way, this thread is worthless without pics of the new bike and new pipes!
Old Apr 7, 2012 | 09:54 PM
JOZ812's Avatar
JOZ812
My son rode his deuce most of a summer with no apparent damage.
But you still do so at your own risk. I would avoid alot of stop and go riding if you do.
Old Apr 7, 2012 | 10:21 PM
beast 10's Avatar
beast 10
the Slim ran fine before and after install, the plugs looked new with a hint of black before and ash white after and has decel popping after install and none before. Heres a pic.
Im not sure why I cant post pics on this fourm ?
Attached Thumbnails My Slim exhaust-478345_422837201076320_100000501318971_1667499_1127722841_o.jpg
Old Apr 7, 2012 | 10:28 PM
OkieNiteTrain's Avatar
OkieNiteTrain
Default XIEDs
http://www.nightrider.com/parts/
Spend a 100 and solve your problem. That is from experience. Too many will tell you put a tuner on it first thing. It just needs to run a little richer.
Old Apr 7, 2012 | 10:45 PM
jlasoftail's Avatar
jlasoftail
any stock harley plug will show white. That being said, without being there and knowing for sure, ride at your own risk
Old Apr 8, 2012 | 06:17 AM
Blk and Chrome's Avatar
Blk and Chrome
I bet they looked the same before you changed the pipes. the O2 sensors will read and the ECM can adjust the mixture to be 14.5-1 to 14.7-1 which is normal. Just ride it. You will get decell popping without a tuner as the stock program will shut off fuel on decell and the fuel thats comes out the pipe will ignite in the pipe causing this. The stock pipes woun't do that do to the restrictive nature of their construction. Basicly less backpressure more popping. A good tuner can get this out with addeing fuel on decell.
Old Apr 9, 2012 | 07:38 AM
beast 10's Avatar
beast 10
Thanks for the replies I'm just gonna run it for a while see how it goes
Old Apr 9, 2012 | 07:51 AM
arrowslinger1980's Avatar
arrowslinger1980
Looks awesome!! Spend the money get a tuner now. Why risk it?? Then when you get an air cleaner you wont have to dump a grand all at once.
Ive had power commander 5 and SERT pro. both will do the trick.
Old Apr 9, 2012 | 10:00 AM
Wide_Open's Avatar
Wide_Open
Bike looks great with the new pipes on it. I agree the Xieds will work fine if you are not planning any more mods.
