Getting ready to order pistons
Old Apr 10, 2012 | 06:27 PM
BLOWN HOWARD's Avatar
BLOWN HOWARD
Default Getting ready to order pistons
Going to order the screaming eagle pistons for my build going from a 88to 95 should i buy the higher compresion pistons or the stock type flat top. Anybody have experience with either one
Old Apr 10, 2012 | 06:57 PM
KumaRide's Avatar
KumaRide
Depends on what you want to achieve. Are cams and/or headwork in the mix? I'd do a lot of research and choose a known, proven build. Whether its andrews 26 or 37 or se 204's with flat tops, may be some headwork or ....? Our 06 heads are great for bolt in cams btw.
Old Apr 10, 2012 | 07:45 PM
BLOWN HOWARD
I am going to run the Dave mackie cams and figured might as well do the big bore while I am in there, leaving the heads alone for now
Old Apr 10, 2012 | 08:10 PM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
talk to dave, he's forgotten more than most people know, he will steer you in the right direction, you really might consider having him get your pistons for you (his) and, have him match the cams with them, his headwork is amazing too. I am running his stuff in my roadglide, and it just kicks a$$!!!
Old Apr 10, 2012 | 09:53 PM
BLOWN HOWARD
Good idea I will call Dave in the am, if I could afford his head/ piston package I would be all over it seen it make big numbers
eazyrider
Jul 5, 2021 08:25 AM
03Custom883
Nov 5, 2017 07:50 PM
hattitude
May 17, 2016 08:17 PM
Mike in Oregon
Jan 31, 2011 09:19 PM
Ganno57
Feb 24, 2006 02:10 AM
