J & M handle speaker install
Old May 3, 2012 | 08:32 PM
Kuminatcha's Avatar
Kuminatcha
Default J & M handle speaker install
Trying to finish up my new speaker install but had a few last minute questions. Where is the best place to run the power wire? Really don't want to run it direct to battery, would rather have it only hot when bike was either running or on acc. Also when running the hot and ground under the tank do I need to add something around the wires to protect them from the heat? Seems they will get pretty hot from the jugs. Thanks in advance. By the way I did a sound check with them and they do sound really good.
Old May 3, 2012 | 08:42 PM
fcsallan's Avatar
fcsallan
Most wiring will be fine with the heat as long as it is automotive grade. That is unless it is touching the hot metal.
I would run a relay for the power if you want it switched with the ignition. The ignition circuit is not meant for the high draw of the amp.
Old May 4, 2012 | 01:13 AM
tunaman's Avatar
tunaman
I spliced mine into the wiring coming off the switch under the console, and thus ran the wire under the console from the front of the tank. It works with the switch in either ON or Accessory position, which is exactly how I wanted it to be.
Roger
moefoties
Electrical/Lighting/Alarm
Jan 30, 2016 02:13 PM
matte
Mar 10, 2012 05:20 PM
Mixter
Aug 14, 2011 04:16 PM
Menloak77
May 26, 2010 10:30 PM
3/4 life crisis
Jan 31, 2009 06:57 AM
