Converting to Synthetic Oil
Old May 15, 2012 | 04:31 PM
motrcop914's Avatar
motrcop914
2nd Gear
Default Converting to Synthetic Oil
I have a 1994 Heritage Softail and was thinking of converting to synthetic oil for extended mileage. However, and old school HD dealer mechanic said he would not recommend that. Does anyone have an opinion both pro and con?
Old May 15, 2012 | 04:36 PM
2011Deluxe's Avatar
2011Deluxe
Wont harm anything, just drain out the old and replace with the new. Synthetic works fine in older motors.
Old May 15, 2012 | 04:47 PM
Tampa Fatboy's Avatar
Tampa Fatboy
I agree with the mechanic you spoke with, dont do it. Now if you rebuild it then do it from the get go.
Old May 15, 2012 | 04:54 PM
motrcop914's Avatar
motrcop914
2nd Gear
what is the issue that makes it not a good idea?
Old May 15, 2012 | 05:02 PM
Robbie13's Avatar
Robbie13
LOSER
I run Amsoil in everything I own. It may not matter, but it gives me a warm feeling inside. It can't hurt.
Old May 15, 2012 | 05:09 PM
2011Deluxe's Avatar
2011Deluxe
None, you can just drop synthetic right in.
Old May 15, 2012 | 05:14 PM
GWIZ2260's Avatar
GWIZ2260
I've never had any problems switching from conventional to synthetic in anything I have ever owned, regardless of mileage. I do not know how this would be any different.
Old May 15, 2012 | 05:20 PM
Tampa Fatboy
Older bikes should use single weight, non-synthetic oil. The logic behind this is that the molecule shape of synthetic oils allow a very thin film of oil that works very well in a modern, close tolerance engine. Older engines have wider tolerances, so they need the larger molecules of a non-synthetic oil. The flatter molecules of the synthetics will leak past piston rings and result in excess oil consumption and potentially glazed cylinder bores. Articles even cautioned against using multi-grade oils for similar reasons.
I have no scientific knowledge of oils myself other than chat between older mechanics about older scoots. In fact, I doubt if anyone here can really call themselves the oil guru. Rebuilds are looked at different. Listen to the others replies in here, chat with a few more, and come up with your own conclusions.
Edit: gonna have to start usin spell chck...laffs
Old May 15, 2012 | 09:19 PM
Dixie Dreg's Avatar
Dixie Dreg
You can switch to synthetic with no worries.
Old May 15, 2012 | 09:22 PM
Superfly3176's Avatar
Superfly3176
How many miles on the bike
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
