probs after new H-D battery
Old May 28, 2012 | 03:38 PM
kalamitty's Avatar
kalamitty
Default probs after new H-D battery
i have replaced the battery of my heritage, due to being 4yrs old, and i replaced it with a genuine H-D battery. now it keeps blowing the headlamp fuse as soon as the ignition switch is turned on. and the running lamps go off as well ( must be same curcuit) everything else is working, i removed the batt in case there was a trapped wire can't see one, and have taken off any accessory power leads but it still blows the fuse. the bike runs but it means i cant use the headlight and no i cant use candles as they keep blowing out. any got any ideas what to do next thanks.
Old May 28, 2012 | 04:20 PM
Mike05's Avatar
Mike05
I had the same problem with my 05 after about 3 months. Turns out the head light was aimed down too much and the wiring wore through on the front fork cover where the wiring passes through. Bike was new and I hadn't ridden in the dark and didn't notice the poor aiming. Otherwise I would have adjusted it before the damage occured.
Old May 29, 2012 | 12:37 AM
kalamitty's Avatar
kalamitty
thanks mike i am going check the wiring back from the lights to the fuse board could just be a coincidence that its happened when swapping battery.
Old May 29, 2012 | 03:10 PM
kalamitty's Avatar
kalamitty
we got around to checking out the wiring, had trouble undoing the screws holding the headlight but couldn't find any chaffing wires, etc. so i put a quality fuse in and bingo everything is ok, must be cheap chinese fuse that the auto shop sold me. i went through 6 before getting a better one.
Old May 29, 2012 | 09:54 PM
mac1911's Avatar
mac1911
Hmmm.
sonar_chris
Nov 22, 2015 04:07 PM
icepick
Mar 10, 2012 11:32 AM
Caestus75
Apr 25, 2009 10:05 PM
scottdoege
Mar 16, 2009 06:47 PM
joshuri
May 31, 2007 11:17 AM
