Fuel gauge
Old Jun 14, 2012 | 10:41 PM
BassCatcher's Avatar
BassCatcher
Guess I'm the lone ranger on this but my fuel gauge works perfectly.
Old Jun 14, 2012 | 10:45 PM
oct1949's Avatar
oct1949
Seem's like several in here have has float issues...
Mine has worked perfect from day one and still does...
maybe someone had removed it from the tank and fudged it up..
Old Jun 14, 2012 | 10:50 PM
soft 02's Avatar
soft 02
Originally Posted by RioCat 53
Probably a thread about this, but is there a way to remove the fuel gauge cap and put a regular screw cap in without jumping through hoops?
Only if you want a dummy cap that serves no function.....like the fuel gauge.
Old Jun 14, 2012 | 11:04 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
I don't think the gauge is wired in any way to the dash light.
But it should be easy enough to check, it will just take a bit of time and mileage.
Just ride it around for a couple of days keeping an eye on the gauge and light.
When it gets down to the level where the light comes on put a little gas in the bike.
Just enough to turn the light off.
Now look under the tank where the gauge is and you'll find the connector for it strapped or attached to the tank bottom.
Disconnect it and reset the trip meter to "0".
Take the bike for a ride that's long enough (about 20 or 30 miles or 3/4 of a gallon of gas) to either turn the light on or prove it is somehow dependent on the gauge.
If it doesn't come on, try plugging the gauge back in to see what it does.
My guess is that it they are not in anyway connected as the gauge works directly off the sending unit.
While all of the dash functions, speedo, gear indicator, odometer, security key light and everything else in it is controlled by the ECM under the seat via a serial data line.
Old Jun 14, 2012 | 11:06 PM
soft 02's Avatar
soft 02
You are correct the light signal comes directly from the sender in the tank. You should be able to remove the gauge and still have a low fuel light.
Old Jun 15, 2012 | 07:48 AM
kzoo's Avatar
kzoo
My gauge works well, but my main fuel indicator is my trip meter. 160 I am looking for gas!
Old Jun 15, 2012 | 07:57 AM
gonzo3426's Avatar
gonzo3426
trip meter...can't go wrong...
although, i've tested the trip meter about 3 months ago:
- cruise control at 75mph on I-81 S, near Harrisonburg, VA
- started sputtering then engine just dies, watched rpm needle drop to ZERO
- turned signal to pull over
- leaned bike over slightly to help slosh fuel
- got it started and luckily enough near exit
- dies again halfway through exit ramp
- leaned bike again to help slosh fuel
- made it to gas station
- pumped 5.7 gal, range of 214 miles, that's about 38mpg average (103ci)
- now, my rule of thumb, fuel up every 200 miles max...
- obviously when you don't dog it, fuel efficiency improves...
my $0.02
Old Jun 15, 2012 | 09:19 AM
QC's Avatar
QC
LMFAO!
Thanks, guys. My gauge is actually pretty accurate, lucky like basscatcher. Just thinking of going with a flush mount set-up. Light comes on reliably at 170-175 miles on trip meter.
Jovann86
Jul 16, 2012 05:50 PM
douggyjb
Apr 20, 2012 08:01 PM
Bill Cavender
Electrical/Lighting/Alarm
Apr 6, 2012 10:24 AM
Crazy Canuck
Exhaust System Topics
Sep 16, 2011 01:42 AM
Bigdaddysstreetglide
General Topics/Tech Tips
Aug 23, 2011 07:45 PM
