Removing Stock Exhaust
Old Jun 20, 2012 | 11:33 AM
johngbrown66's Avatar
johngbrown66
Default Removing Stock Exhaust
I got all the bolt and clamps loose but am having trouble getting the mufflers off.
Any tricks or advice?
Thnks
Old Jun 20, 2012 | 11:53 AM
TheTroupe's Avatar
TheTroupe
http://lmgtfy.com/?q=Exhaust+removal+2011+Fatboy
Old Jun 20, 2012 | 12:06 PM
Sgt_Jim's Avatar
Sgt_Jim
If it's anything like the stock exhaust on my 2010 Lo, there's probably a cross-over pipe on the mufflers, making the entire thing 1 piece.. so once you unbolt the bracket from the frame (below the passenger peg), and get the exhaust flanges unbolts from the cylinders, just gotta monkey with it until it comes off.. it really helps to loosen up the floorboard and give yourself some extra wiggle room too
Old Jun 20, 2012 | 12:41 PM
oct1949's Avatar
oct1949
Back in my Millwright days, anything that came off or went on hard..
We would just get a (BMFH'er)
AKA-- Big Mother Fu(king Hammer...
Really U just have to work and wiggle them. or if U have a Knocker tool U can use it to help.
Old Jun 20, 2012 | 12:51 PM
08Nighttrain's Avatar
08Nighttrain
Rubber mallet is very useful tool with alot of tough parts.
Old Jun 20, 2012 | 01:49 PM
CT-Mike's Avatar
CT-Mike
+1 on loosening the floorboard. I couldn't get the pipes off my Heritage until I did that.
Old Jun 20, 2012 | 03:27 PM
Fierofly's Avatar
Fierofly
I've had mine on and off a few times now. Cam and Tire changes , Use a strap wrench to turn each muffler back and forth while pulling after spraying with WD40.
Old Jun 20, 2012 | 05:09 PM
johngbrown66
Thanks for all the tips, I finally figured out a quick shot of WD40 and the turned and came right off. The Rush slip ons 1.75 went on quick and easy, longest part was getting the old ones to slide off. Sounds good now and I am impressed I was able to do it my self. Guess my next oil change will be done at home as well.
Thanks again everyone
Old Jun 20, 2012 | 05:20 PM
fish-r-ride's Avatar
fish-r-ride
When You had the stock mufflers off did you go a head and turn the rear axle bolt around so you won't have to pull the mufflers off again when you put on a new tire. If not be sure and do it when you put on a new one.
Old Jun 20, 2012 | 08:58 PM
Fierofly's Avatar
Fierofly
Nope didn't even think about it, DUH!! Guess I'll have to do it after the Michelins wear out.
