rocker with cruise control
Old Jul 9, 2012 | 06:32 PM
mikemnkt's Avatar
mikemnkt
Default rocker with cruise control
well i figured it out.electronic cruise control on bike and works good.and the best part i only have 360 dollars invested in setup. sorry post pics later.just figured it was time to have it on a softail without going broke
Old Jul 9, 2012 | 06:59 PM
mikemnkt's Avatar
mikemnkt
i used a rostra kit along with a dakota didgital part to make work and i had to cut no wires onb bike.230 for rostra and 130 for dakota part.it plugs into data port to give a tach signal a pulse signal and a power and ground.hook up to it and mount cable to throttle body and bingo cruise cheap
Old Jul 9, 2012 | 07:05 PM
FroggyFatBoy's Avatar
FroggyFatBoy
what yr is your bike and some part numbers for the parts used would be great. I was looking at the rostra kits before and thought about mounting the cruise module/servo in a swingarm bag.. mount it solid of course.. where did you mount the servo assy ?
Old Jul 10, 2012 | 07:14 PM
mikemnkt's Avatar
mikemnkt
i mounted the servo under the horn using the horn bracket 2008 rocker.part numbers are from dakota didgital the cruise is crs3000 and data part is stm-100 you can hook up without that part but will need to splice wires. the controller i picked with the cruise to turn on is the hnd-2 it is a little box that is 1x2 inches i mounted on side of bike by key any questions feel free to call me mike at 507-381-+6416
Old Jul 11, 2012 | 02:37 PM
lionsqrne's Avatar
lionsqrne
Could you show pictures of this on your bike? and a wire diagram if possible. The pics would really help out though.
I am very interested in this.
Old Jul 11, 2012 | 03:26 PM
serjayson's Avatar
serjayson
+1 would like to know more about it. Thanks
Old Jul 11, 2012 | 04:01 PM
purecountry13b's Avatar
purecountry13b
Pics please.
Old Jul 11, 2012 | 04:20 PM
harleyheaven's Avatar
harleyheaven
subscribed...
Old Jul 11, 2012 | 04:32 PM
mikemnkt's Avatar
mikemnkt
will work on pics i always have a hard time posting them can text if needed.the wiring is really simple 1 hot 1 switch hot 1 ground 1 tach wire 1 vss speed pulse wire and done very simple the only bad thing is the servo is 4x5 3 inches deep.tou could easily put in saddle bag to hide i did not have that option
Old Jul 11, 2012 | 04:34 PM
mikemnkt's Avatar
mikemnkt
cable was easy hook up on the side of throttle body is a mounting hole that i drilled out to fit the cable and it came with a part that will snap on the side of throttle body where your cables hook up very simple anyone can do i will try getting pics to explain better
