Alright, well my cams are suppose to be in friday, or early next week. so quick question, besides my new cams... SE204s, what else do i need as far as gaskets bearings etc? any special tools?
Also is it worth the $180 for the adjustable pushrods? seems to be the way to go for ease of install, no having to open the rocker boxes and remove tank and such...
You will be ahead of the game if you replace your inner cam bearings with Torrington bearings.
You will benefit from the cam and bearing install tools but you can risk disaster if you are really good with a press and have a variety of pieces of iron laying around as far as getting the cams out and back in the support plate. You will need the bearing removal tool and probably the install tool.
If you have some miles on the bike you will probably want to replace the cam chain tensioner shoes. You will be able to change those out as a regular maintenance item if you get the adjustable push rods (one of the side benefits of doing so).
Cam cover gasket.
If your existing cam is in good shape, that should do it.
Yup, going in my 07 deuce 96"... already has pipe intake and sert... just want that little extra umph .... bike only has 6k miles so r the new bearings needed? And r they hd bearings or where do u get them
With only 6k U don't need to replace the lifters.. but if U take them out of the holes make sure U number them so they go back in the same position/hole as they are now.
