Fxstd problem, please advise!
Took speed sensor off of 2000 heritage, install on deuce, no good. Replaced ecu, no good. Replaced ign switch, speedo, no good.
Disconnected harness plugins under gas tank to all switches, controls, headlight, and rear lights, disconnected ecu, map sensor, still popped acc fuse at turn of new switch. I replaced voltage reg as well. No good. Anyone have a clue as to what this could be?
I went through the entire wire harness and found not one chaffed wire. I did a DTC with the odometer, and the only codes I now have are the CKPS, and BAS. I hate electrical problems
