Softail Handling in Curves
Old Jul 16, 2012 | 10:57 PM
rleedeuce's Avatar
rleedeuce
Default Falling over on one side
Was wondering if anyone had any ideas why it would do this turning right but not left. Most things will affect steering in both directions. Be nice to pick up anything needed while we're in the States rather than finding it out after getting back home.[/quote]
If bike rear wheel is pointing hard to the right your bike will feel like it is "falling over" to the right because of center of gravity problems. Left hand turns will still feel reasonably balanced.
As for being in a strange land without your trusty "alignment blocks" why not just use a piece of string. String works great if you check your work a couple of times and are patient...
I trust the string method because sometimes Harley marks the rear swingarm wrong. There simply is no way to set the wheels crooked if you can "see" that both tires are tracking exactly 100% in the same angle---straight ahead---when adjusted in relation to the string.
You will of course have to check belt deflection once you jack the wheel around looking for a perfect straight line up. As you move the wheel you will be messing with the belt tension...
But really any Harley guy should be able to do alignment, belt and fall away in his sleep. There is no other way to get a Harley to track correctly if you let these things get away from you.
If you don't know how to use a long string to set the wheels straight look for it here:
https://www.hdforums.com/forum/softa...ml#post8412071
Old Jul 17, 2012 | 08:38 AM
NDBadlands4-2's Avatar
NDBadlands4-2
Check the alignment of the wheels. If the bike has ever been wrecked prior to you getting it the frame may not be perfect and that would cause such an issue.
Old Jul 18, 2012 | 09:34 AM
95yj's Avatar
95yj
Thanks for the response. This makes a lot of sense. I've never run across this before because I always do my own work on the bike including pulling the wheels to change tires and then resetting the wheel alignment. The entire trip, the front wheel did feel like it was turned to the right a smidge. Funny thing is that it was this way when I got it, then I had the rear tire replaced by an indy in Daytona and it was still this way and then I caught a nail and a staple in the rear in Arkansas and had a stealer put a new tube in and it was still this way. If the alignment is off all three times, that means they just tightened it back to the original thread turns. I'll check it once we're back in the States for Biketoberfest.
Regarding a wrecked and bent frame, this is a two owner bike and I was assured the bike had never been wrecked and also nothing shows on cyclevin.
Old Jul 18, 2012 | 09:51 AM
whflht's Avatar
whflht
95yj I agree the frame needs to be checked. A friend of mine had the same problem with a FLHT he bought. The owner swore it was never wrecked but turned out some how the frame was bent. I would take it to a shop and just have it double checked. Good Luck how you figure it out and keep us updated I am curious what you find out.
Old Jul 18, 2012 | 06:16 PM
rleedeuce's Avatar
rleedeuce
Default Bent frame or just wheels crooked
I would do the cheap (how much does a string cost) crooked wheel check first. See if you can get the rear wheel perfectly aligned with the front.
If the bike is still messing up then you can justify dragging the whole mess over for a shop to check the geometry of each part. Getting a shop to put your forks, swingarm and frame in a jig and looking for a bent suspension member sounds like Ka-ching Ka-ching to me...
A string on the other hand don't cost squat.
West_Tn_Biker
May 7, 2022 12:50 PM
propflux01
The Dark Side
Nov 9, 2020 07:00 PM
Timmy B
Feb 23, 2014 01:35 PM
shanvhere
Jun 24, 2013 08:24 PM
MOTOKILLER
Feb 14, 2011 12:10 PM
