UGH!!! One step forward, Two steps back...
Old Jul 23, 2012 | 12:05 PM
  #61
Branner's Avatar
Branner
Looks to me you mounted it incorrectly. Every sidemount I've seen sticks out more & is level, yours is tucked in too close to the tire and appears crooked (IMHO). It also looks (to me) as if that mount is designed to be mounted on the bottom arm of the swing arm rather than on top. In any event, while it sucks that you have some damage, it could've been worse.
Old Jul 23, 2012 | 12:07 PM
  #62
Thor's Avatar
Thor
Originally Posted by ghoticov
Took the bike this morning to a body shop to get a quote on fixing it. This is a mom n pop shop that has a very good reputation.
They said it would be no more than $200 and they should have a candy apply red that they can shoot through their system that will be a 95% match. He said they use a water base but he said even if the rest of the bike is lacquer based, that is OK...you can mix the two. He said because of where it is (below the chrome piece), he said you won't be able to see the difference.
I have to bring him the fender and the chrome side piece so he can make sure he doesn't paint past that.
Does anyone have a good site that shows how to take off the rear fender? I know it can't be that hard but if it comes down to rewiring things (maybe the blinkers?), it could be tricky for me.
Told ya
Disassembly is fairly straightforward. If I get home at a reasonable time, Ill scan and email the page covering r&r
Old Jul 23, 2012 | 12:14 PM
  #63
tlb's Avatar
tlb
http://tampa.craigslist.org/pnl/mcd/3098931630.html
Old Jul 23, 2012 | 12:27 PM
  #64
ghoticov's Avatar
ghoticov
Originally Posted by 08Nighttrain
Easiest way would be to unplug the rear wiring harness right under the sea then remove the two strut bolts on each strut that connect to frame this way the entire back fender assembly will come off in one piece and make it alot more manageable on a work bench to remove the rest of the parts. It will be alot easier to see and reach them too. The dissasembly is very easy once you get the thing on a bench and can get at the stuff. several bolts a couple light connectors the only thing that is a pain is the black rubber channel that the wireharness runs through mounted under the fender the plugs on either end wont fit through and you best bet is to leave it on the fender just tape up the ends and it should be fine.
Perfect! That's the info I needed. I think I can leave the tailight attached with all the wiring. I was also thinking the shop should be able to just tape off when they go to paint. My main concern was just getting the fender off and the chrome side pieces as all...or atleast be able to get them off enough to move out of the way.
Old Jul 23, 2012 | 12:30 PM
  #65
ghoticov's Avatar
ghoticov
I believe it was meant to mount on the lower part of the swing arm also. It is crooked because I rotated it so it would clear the fender...before that it was straight. It came with no instructions and its my own fault for not looking at the clearance when sitting on the scoot.
Old Jul 23, 2012 | 12:31 PM
  #66
ghoticov's Avatar
ghoticov
Originally Posted by carpenter115
Told ya
Thanks man!
Old Jul 23, 2012 | 12:41 PM
  #67
soft 02's Avatar
soft 02
Cool but wrong color. His is fire red pearl with black pearl.
Old Jul 23, 2012 | 12:50 PM
  #68
ghoticov's Avatar
ghoticov
Exactly. Good find if I liked the color and wanted to change all the tins. For $200 I can get mine fixed and love my color.
Old Jul 23, 2012 | 12:52 PM
  #69
tlb's Avatar
tlb
It's a full paint set, at a good price. I was not attempting to match his color. I just wanted to give him an idea of what the cost is to get a complete set.
Old Jul 23, 2012 | 12:54 PM
  #70
soft 02's Avatar
soft 02
No thats cool but yes the orig fire red is bad ***. Great deal too!
