engine/battery lights on
Old Jul 22, 2012 | 04:16 PM
kalamitty's Avatar
kalamitty
Default engine/battery lights on
i have a 2005 heritage and the battery was replaced approx 2 months ago and i completed a 170 mile ride with no trouble, but today at approx 190 miles when stopping at a red light i noticed the engine (orange) and the battery (red) lights were on, the ones in the speedo, i switched off the passing lamps and first the red light went out shortly followed by the orange when i increased the revs, after approx 5 miles i thought i would switch the passing lamps back on just to see if it was a fluke, and the warning lights returned, so switched off the passing lamps untill i got home, battery was reading below 12.5v but the bike still started, anyone any ideas what to look for?
Old Jul 22, 2012 | 04:18 PM
kalamitty's Avatar
kalamitty
sorry i posted this question twice.
Old Jul 22, 2012 | 05:44 PM
Mark_H's Avatar
Mark_H
Sounds like it could be a Rotor/Stator issue. I'm assuming when you checked the battery voltage when you returned that you checked you battery connections where tight.
If its nothing that simple I suggest reading this how to:
http://blog.jpcycles.com/step-by-ste...arging-system/
Old Jul 22, 2012 | 08:16 PM
jmg343's Avatar
jmg343
sounds like either your voltage regulator, stator, or both.
Old Jul 22, 2012 | 08:59 PM
GWIZ2260's Avatar
GWIZ2260
Would check voltage regulator first as I have heard that they go bad quite often. Good luck.
hyfly1
Aug 28, 2012 01:40 PM
GENRLEE01
Aug 24, 2011 11:34 AM
rekesbass
Sep 12, 2010 12:24 AM
FLHXXHLF
Feb 4, 2010 06:44 PM
jhughes484
Sep 14, 2008 10:15 PM
