Intermittent Battery Light
Old Aug 27, 2012 | 01:34 PM
hyfly1's Avatar
hyfly1
Default Intermittent Battery Light
As I was at mile 5 of a 500 mile trip, the check engine and battery lights went on. I headed for the nearest dealer, but within a few miles both lights went out and stayed out for several days. I checked the codes, and it came back "Battery Voltage Low". Yesterday, after the bike had sat for about 40 hours, I started back home and the same lights went on. After a few miles, the lights went out again and did not re-appear. I made several stops, and the bike always re-started normally. I have not checked the battery, but with it continuing to start strong, I don't think that is the problem. I also don't think it it the stator or voltage regulator, since I have easily put on 500 miles since the lights first appeared, and the battery does not appear to be drained.
What would you do?
Old Aug 27, 2012 | 01:47 PM
mkguitar's Avatar
mkguitar
take the battery out of the bike
put it on a real battery charger over night at a charge rate of 2 or 5 amps ( 10 amps is too much, too soon)...not a trickle charger/tender
take to an auto parts store like auto zone have load tested ( or dealer can do it)
IF the battery is on it's way out, it can stress the charging system to the point of failure which is $$$
mike
Old Aug 27, 2012 | 01:48 PM
danny4127's Avatar
danny4127
Check cables
Old Aug 27, 2012 | 01:53 PM
fwb35's Avatar
fwb35
Sounds like battery is not holding a full charge after sitting for a while
Old Aug 27, 2012 | 02:03 PM
dbell66253's Avatar
dbell66253
You might want to do a load test on the battery, also check to make sure the connections are secure, if you still have it happening after that, I'd say the VR is starting to give signs.
Old Aug 27, 2012 | 08:50 PM
Mathews2's Avatar
Mathews2
What model bike. Could be a bad VR Word of caution. If it is the VR and it goes you are stranded.
Old Aug 28, 2012 | 10:50 AM
hyfly1's Avatar
hyfly1
I suspect the battery is not holding a charge, and will check that tonight before I start out. My plan is to check the battery before, ride for a while, check it again and see if the voltage changes. Since it is only an intermittent fault, I am hoping that the system is working properly when the idiot lights are not lit. Does this make sense?
Old Aug 28, 2012 | 12:25 PM
mkguitar's Avatar
mkguitar
...as above;
so your little ride could get expensive
mike
Old Aug 28, 2012 | 12:48 PM
Weavr99FLHT's Avatar
Weavr99FLHT
mike
Why not a tender. Deltran Battery Tender, from their website:
■Temperature compensated to ensure optimum charge voltage according to ambient temperature.
■Automatically switches from full charge to float charging mode.
■Battery TenderŽ at 1.25 amps will charge as fast or faster than any 3 amp charger available.
■Reverse Polarity Protection to ensure user safety. Red & Green Lights Alternately Flash in this condition.
■Complete 4-step charging program (Initialization, Bulk Charge, Absorption Mode, Float Mode).
■10 year Warranty!
Old Aug 28, 2012 | 01:33 PM
btsom's Avatar
btsom
WHEN THIS HAPPENED TO ME on my 08 Road King I disconnected both plugs on the voltage regulator and cleaned the plugs and prongs as best I could, applied dielectric grease and put it all back together. Have not had a repeat since (about 6 weeks and 500 miles.)
