Changing fork oil FXST
Old Jul 27, 2012 | 03:21 PM
rancid13's Avatar
rancid13
Default Changing fork oil FXST
Guys, I've seen write ups about how to do this and how easy it is. It seems easy enough... I've got the bike on the jack. Forks extended, unscrewed drain screws, drained fork oil. Unscrew top bolt at top of forks.... I can't pour fork oil in there... I've taken the forks out of the triple treese many times, but never done this. I could see how if I dropped the forks down out of the trees and unscrewed that bolt thats under pressure then poured the new oil in and closed it all back up. But that's not how the manual says to do it, and thats not how anyone on here has described it. Little help here....
Old Jul 27, 2012 | 04:45 PM
95"06Nightrain's Avatar
95"06Nightrain
if it is a standard wideglide fork setup like my nightrain, you should be able to fill thru the large bolt hole on the top of the triple trees. If that doesn't work, loosen the pinch bolts in the bottom tree and slide them down far enough to remove the bolt fitting. It'll be skinny with a 2 flat area that you can wrench off. The springs will more than likely have a fairly heavy preload on them because of the lowering, so keep a handle on it and don't point it straight at your face.
Old Jul 27, 2012 | 04:55 PM
rancid13's Avatar
rancid13
Thats exactly what I wanted to know. So it is acceptable to drop the forks and remove the bolt under pressure and fill it through there... Thanks.
Old Jul 27, 2012 | 07:29 PM
95"06Nightrain
No problem
Old Jul 27, 2012 | 09:20 PM
Scuba10jdl's Avatar
Scuba10jdl
With FX/XL front ends, I just take the whole tube off the bike. Unscrew the fork cap (off the bike there isn't that much spring pressure at all) and pour the old oil out from the top, and then refill with the wet amount from the manual.
I've found those little drain screws at the bottom are a pain in the ***.
Old Jul 27, 2012 | 09:49 PM
Jim Kraft's Avatar
Jim Kraft
I guess I don't understand why you can't pour fork oil in the hole you took the cap out of. I have changed mine on my 99 FXSTC without a problem. I did use a funnel to make it easier without spilling any.
Old Jul 28, 2012 | 11:32 AM
oct1949's Avatar
oct1949
Same here on our 07 Heritage.. must be diff..
Old Jul 28, 2012 | 01:31 PM
ghostrider69's Avatar
ghostrider69
You can use a funnel. You have to make sure the funnel is small enough to fit down thru the hole to allow the oil to flow freely past the threads. If not then the oil will not flow into the tube very well if at all.
Old Jul 29, 2012 | 04:40 PM
richmac64's Avatar
richmac64
When I changed the fork oil on mine I added it through the top as well. Was surprised how easy it was to do because I was expecting alot of pressure when I took the top bolt out.
XTonerman
2014-2024 Touring Models
17
Nov 19, 2021 04:39 PM
FXD_noob
Nov 3, 2014 11:02 PM
bjewell
Jun 21, 2011 11:47 PM
PPBART
May 19, 2011 12:01 PM
The Baron
Jan 23, 2008 11:00 PM
