27 tooth compensating sprocket?
Before, I would be in 5th around 50-55MPH. With the 27t, I'm slippin into 5th around 60-65MPH.
I did a little research, if you want to get up and go to max RPM ASAP, then stock or 23t. If you want to do highway cruisin all day at 75-85, the 27t is an interresting alternative.
My interest was in riding with my crew (all of whom own the 6 speeds) and wanted to get that performance without the cost.
Engine sprocket means no recalibrating the speedo... everything from the tranny back and recalibrating is a must (unless you are capable of doing the math in your head.. ha!).
Illusion Cycles in California (www.illusionmotorcycles.com) is where I finally found it. Those folks were easy to talk to and do business with. The cost, $250, was a bit steep (IMHO).
Hope this helps
$125.00.....go down to close to the bott. of file.
I have a 99 low rider with a somewhat built 88, I ride mostly 2 up and just got done with doing the 27 tooth...I can't believe that I could barely tell the difference on the bottom end, leaving stop signs in 2nd gear. What I did notice that doing 70-75 was still under 3 grand on the ole tach......which was what I was trying to achieve...Was worth the $........
Gammy
Gammy
