help ball joint wont come off
Old Aug 2, 2012 | 09:13 AM
mrdjc99's Avatar
mrdjc99
Default help ball joint wont come off
Hi im joe, 24 i have a 96 evo fatboy i broke the shift linkage ball joint onto the rear shifter and now i cant get it off! Any ideas or helpfill info i know im trying to turn it the right way.
Thanks
Old Aug 2, 2012 | 01:05 PM
oct1949's Avatar
oct1949
Vice grips and correct size wrench..
Maybe try to turn it the other way,, Just in case U are not turning it the right way...
wouldn't be the first time in here that something is that easy to fix..
Old Aug 2, 2012 | 01:15 PM
SouthpawHD's Avatar
SouthpawHD
I'm trying to picture that piece, so I might be wrong - but isn't is possible that piece might have a set screw in it?
Old Aug 2, 2012 | 02:35 PM
stng_96's Avatar
stng_96
No set screw, if its already broke and your taking it off to replace just put an angle grinder on it
Old Aug 2, 2012 | 03:33 PM
mikkeeh's Avatar
mikkeeh
did you back off the locknut??
Old Aug 2, 2012 | 04:49 PM
QC's Avatar
QC
If I remember correctly, the ball is a threaded stud mount with wrench flats on the ball side and a nut on the back side. Relatively small, 8 or 9 MM.
Old Aug 2, 2012 | 06:07 PM
jreichart's Avatar
jreichart
A pic of what you're left with would really help.
Old Aug 2, 2012 | 08:04 PM
mrdjc99's Avatar
mrdjc99
Well i was correct in turning it the right way so after nearly popping ever vein in my neck & applying heat from a mini torch from harbor freight it finally came off! Thank jebus! But now the new on from harley wont come off to put on the bent rod that came with my samson true duals!
Old Aug 2, 2012 | 08:37 PM
QC's Avatar
QC
OK, Now we need pics!!
Old Aug 2, 2012 | 11:40 PM
mrdjc99's Avatar
mrdjc99
Finally fixed it!!! although 1 problem down another arises, this time with those crush gaskets! since i had everything torqued i had to loosen them up to adjust everything around and im not to sure if i saw flames pop out of the exhaust/head, but im sure i did so im guessing your not supposed to reuse them. To top it off my harley, the "biggest" harley dealership in texas maybe the world carries nothing in stock! i had to special order my first set!
Attached Thumbnails help ball joint wont come off-img_20120729_193509.jpg   help ball joint wont come off-2012-07-19_19-59-25_672.jpg
