What is this connection/wire?
Old Aug 11, 2012 | 11:44 PM
edgrabel's Avatar
edgrabel
6th Gear
Default What is this connection/wire?
Does anyone know what this connection/wire is for?
I pulled off my air cleaner and this is what I found. I have a 2007 FXSTD. My brother has one too and he pulled his air cleaner and found the same connection/wire hanging there like in the picture.
Anyone know what this is for or where it might go? Both bikes are stock.
Thanks,
Ed
Attached Thumbnails What is this connection/wire?-tps-capped.jpg
Old Aug 12, 2012 | 12:44 AM
NickD's Avatar
NickD
The plug goes into the back of the air cleaner on California and some European model bikes. It's called an is Active Intake Solenoid switch and when you shut the bike down it closes the throttle plate so gas fumes can't escape into the atmosphere. You can just zip tie it up out of the way or remove it altogether.
Old Aug 12, 2012 | 01:50 PM
edgrabel's Avatar
edgrabel
6th Gear
Thank you NickD for the answer to my question.
Ed
Old Aug 12, 2012 | 07:00 PM
TheTroupe's Avatar
TheTroupe
Never cut the blue wire.
Old Aug 12, 2012 | 07:20 PM
Markske's Avatar
Markske
As NickD already mentioned, it is just the wire that controls a small "flap" at the entrance of the stock air intake. It's standard on all European models, maybe also Californian ones.
I didn't cut it, just tie-wrapped it away behind the intake manifold.
Old Aug 12, 2012 | 07:24 PM
RANGER73's Avatar
RANGER73
Try to seal the end so water can't get in there.
robbyville
General Topics/Tech Tips
Jun 19, 2014 10:47 PM
Jeff Myers
Mar 3, 2014 07:33 AM
Jeff Myers
Mar 3, 2014 12:22 AM
Jmbeebe0722
Aug 17, 2013 03:37 PM
jupiter2
Nov 6, 2011 11:52 AM
