Crossbones Turnsignals
I bet this question was saked like 1000 times before. I surched the forum for answers, but I couldn't finde one. So here it comes again.
I am about to swap all 4 Turnsignals into 2 CATEYES in the Handlebars of my Crossbones 2009.
Now I read on other Sites that if you swap 4 into 2 the TSM will reset the old reistence to the new one and I dont need to install a load equalizer. Is this true?
Here is one example to reset your TSM that I found on a other Site. But to be honest I can't believe that it will work....
step # 1. move handle bar kill switch to off position
step # 2. turn your ignition key: on-off, on-off then on
step # 3. hit the left turn signal twice.
your turn signals and indicator light will flash 1 - 3 flashes
step # 4. hit the right turn signal once.
turn signals and indicator light will flash once.
step # 5. hit the right turn signal once.
turn and indicator signals will flash twice.
step # 6. hit right turn signal once.
turn and indicator signals will flash three times.
step # 7. hit left turn signal once.
turn and indicator signals flash to indicate error code
(see error code thread)
step # 8. to now clear codes, hit left turn signal and hold down for 6 seconds until confirmation.
turn and indicator signals flash twice.
step # 9. turn the ign switch to off
