Which Red tail/brake light?
Old Aug 31, 2012 | 02:02 PM
2003Custom1200's Avatar
2003Custom1200
Default Which Red tail/brake light?
Well this spring put the smoked tail light on my Deuce, came with a red 1157 bulb.
last night i noticed that i had no tail light on the way home, and no brake light either.
Got home pulled the bulb it was fried.
This morning ran into town, comes up non existant at the auto parts stores. Ran to the harley shop 15 miles away. Nothing in stock.
I have to run up to J&P sometime this weekend. Luckily its only 40-50 miles away.
Question is, Which red tail light bulbs are you guys using?
standard red 1157?
the 360* led?
or just the rear facing led?
Ive read some reviews that the leds are not really that bright and just use a regular bulb.
Old Aug 31, 2012 | 02:05 PM
08Nighttrain's Avatar
08Nighttrain
I dont run a seperate brake light so I want mine to be bright and i found that a 1157 red bulb works best even with smoked covers.
Old Aug 31, 2012 | 02:37 PM
Skeezmachine's Avatar
Skeezmachine
At one point I was considering using red bulbs so I could switch my red lenses to smoked on the rear of my bike. I soon found out that almost no one carries red light bulbs and part of the reason places like auto parts stores didn't is because they are not considered DOT. There was one lone cycle place in my area that did carry red bulbs from Kury but at 11$ a pop (PER bulb) or having to order them online for not much less I decided to just not bother.
Were you able to secure red bulbs in your area? What did it cost for you to replace them?
Old Aug 31, 2012 | 03:48 PM
PanHeadRich's Avatar
PanHeadRich
Custom Dynamics has the best & brightest LEDs available for our bikes. Ideally you want an array rather than a bulb. Even with the smoked lenses they're insanely bright. They even have a life-time warranty ... but, they're not cheap. However if you want to be serious about the best LED lighting for your ride, they probably have an array for your model.
I changed every light on my bike to LEDs. Speedo, dash, license, front fender, signals, brake & headlight. Tail/brake & signals are from Custom Dynamics and they're the best I've ever seen.
http://www.customdynamics.com/street...taillights.htm
Old Aug 31, 2012 | 03:51 PM
soft 02's Avatar
soft 02
Brighter than those Brightasslights?
Old Aug 31, 2012 | 03:54 PM
RANGER73's Avatar
RANGER73
For $68.00 for an LED conversion kit, $2.00 for an 1157 standard or $11.00 for a 1157 LED 360. Just replace the bulb, look at the money you'll save as well as the headaches.
Old Aug 31, 2012 | 05:53 PM
2003Custom1200
Yeah, found a bulb. Jp cycles. Gonna run up in the morning. Only a 30min drive from.home. gonna grab a.few of then to keep in the box
Old Aug 31, 2012 | 07:58 PM
PanHeadRich
I honestly don't know which are brighter, I've never seen a side-by-side comparison.
Old Aug 31, 2012 | 08:27 PM
SprungDave's Avatar
SprungDave
For a tail light, go 2357. Works like/constructed like an 1157, but is brighter on the "stop" filament. I have not seen a red 2357, but you could always use colored glass paint. $1 each.
Old Sep 1, 2012 | 05:50 AM
Snowyone's Avatar
Snowyone
I'm with PanHead on the led light array. Just run down the Alcan with my two brothers and one had the led light and the other had the laydown lens with a 1157. There was night and day difference on the visibility. The 1157 looked like a bic lighter behind the lens when the lights got a bit dirty. You want to be seen in the rear so what's your life worth?
PGDredd
May 26, 2010 01:55 PM
Gregte
Sep 2, 2009 02:45 PM
Dustmaker
Aug 6, 2008 09:38 PM
Badpig521
Feb 9, 2007 09:00 PM
Abnmarine
Aug 17, 2006 09:07 PM
