Bad race tuner
Anybody else having issues with their HD screaming eagle race tuners?
Actually wonder if the problem isn't with the Wrench rather than the tuner.
Thinking to work with Ur dealer and see if either They or MoCo takes care of Ur issues..
let us know how it comes out...
On the bright side, they found my front wheel bearing was shot and replaced that considering I'm going on a road trip next week. With that bearing locking up on me and me flying over the handle bar still kind of lucky I guess.
Also I don't know if a SE tuner can be mishandled and end up not working.. like getting too hot or being near a Magnet.
I am betting Ur dealer gave U the wrong tuner after they tuned it.
Whats bad also is that someone else will have the same problem If U got the wrong one back cause they have Ur tuner..
U might check the dealer that tuned Ur bike and see if they can look up the other bikes that was tuned on the 2-3 days before and after Urs to see if anyone else has the problem.
OK I just looked at mine...
I was hoping the box and the tuner had Serial No's on both so U could see if they matched.. but they don't
My box has - 32107-01G - on it
My tuner has - 321140-01A on it and dated - 04/27/07
Which I had it installed around June of 07 at the 1 K.
But my tuner does have my Name on it and another NO... 159AE003005.. which one of the turner's added to it, That may be the number they assigned to the dyno tune.??
Does Ur tuner have anything written on it.????
I will add my dealer had to retune mine after the install because the wrench that put the muffs on did a bad job and had air leaks,, BAD.. so they retuned it 4-5 days later .
Also when I did the cams at 16k they retuned her again..
So I would have known about it real quick if I was given the wrong one..
If U got the newer SEPST its supposed to be even better and easier to tune than the older SERT's..
Also I've read the tune takes about 1/2 the time now (in the right hands) and U end up with a better tune..
