Dead Creek Cycles lowering kit
Old Sep 12, 2012 | 10:39 AM
Wide_Open's Avatar
Wide_Open
Default Dead Creek Cycles lowering kit
Looks like the 1 1/2" inch lowering kit has been replaced by a 2" kit. I had just decided on the 1.5 too. If you look for the 1.5 on their website you get re-directed to the 2". Can't make up my mind.
http://www.deadcreekcycles.com/error...d=704&prdinc=1
Old Sep 12, 2012 | 12:56 PM
bikerlaw's Avatar
bikerlaw
Maybe they will keep both. I bought the cheap bolts because I wanted adjustability. But had I known about the dead creek kit I probablly would have bought it instead.
Old Sep 12, 2012 | 02:46 PM
Bocifus's Avatar
Bocifus
I just installed the 1.5" a couple of weeks ago. With the 39" cholos I have, 2" might be pushing it. I like the looks of the 1.5", plus the Deluxe is already pretty low.
Old Sep 12, 2012 | 03:07 PM
Green Hornet's Avatar
Green Hornet
Bolts work good for solo riding in my opinion, if you ride two up i would look into other options.
Old Sep 16, 2012 | 03:25 PM
Wide_Open's Avatar
Wide_Open
Well never mind. Put the bike up on my crappy Sears yellow stand to see if I was going to have room to work and it doesn't look like I do. Guess I'll have my indy do it with the bolts.
Old Sep 16, 2012 | 03:42 PM
jreichart's Avatar
jreichart
Just put a couple 4x4's stacked front and rear of frame, or jack stands, then lower the bike onto them and remove the jack. Gives ya room to work on the shocks.
ghoticov's Avatar
ghoticov
I did it with my jack from Harbor Freight, which is essentially the same jack from what I know. It should work.
Old Sep 16, 2012 | 03:43 PM
ghoticov's Avatar
ghoticov
And you can do that also.
Old Sep 16, 2012 | 06:12 PM
Wide_Open's Avatar
Wide_Open
Is the Harbor Freight one the same as the Sears yellow or the red one?
I'll get some 4X4's and try them.
Old Sep 16, 2012 | 06:22 PM
Misbehaven's Avatar
Misbehaven
I used a Sears red jack and had no problem doing my kit even with my big hands. I do have to admit that it took a couple of tries to get the jack just in the right spot and it was a tight fit but I got her done.
