Crazy Monster Build thread
The rear brake master cylinder uses DOT 5 brake fluid. The CBR rear caliper uses DOT3. I know DOT3 and DOT4 can be used in place of each other, but I thought 5 was not compatible with 3 or 4?? Will my rear caliper work with the DOT 5 fluid??
Thanx for any info.
Thanx for the info.
I am ready to pull my friggin hair out!! I thought I would have it all together before work tonight. As usual, something you figured would take 2 minutes is taking 2 hours. I bolted the inner primary up and went to put in the starter jack shaft. The friggin bolt just wont grab the starter shaft and suck it all in. I am completey confused as the starter moved over with the tranny, so the offset kit should not have effected anything concerning the starter. Any info on this wouyld be great??? Oh well, I gotta go to work now. Will take a look at midnight when I get home. I also trimmed the bracket and put shorter springs on the seat. Looks way better.
Tons of refining to do so dont be too hard on me. Just tryin to get her on the road. Have all winter to tweak!!!!
Hope to take a rip tomorrow!!!
Shackle (big piece of angle steel running forward as brace, super strong)
Holy ****, I think the bike is about 250 lbs less, pushing it around the driveway was like a mini bike!!!
Look mom, I got a friggin chain!!!!
P.S. Love the snow in the background! Glad I live in Florida!
has to be installed correctly. Try turning the coupling around and
re installing it.
