Swingarm Bags and Side-mount Plates
Old Oct 3, 2012 | 04:34 PM
Rock Southbrook's Avatar
Rock Southbrook
Question Swingarm Bags and Side-mount Plates
Just wondering what everyone is using for side-mount tag brackets when running a swingarm bag on the left side. I have seen both the axle mount and the swingarm clamp variations for the side-mount brackets. I am riding a 2011 Rocker C and I suppose my concern is that with the clamp version, it will require the bag to be pushed forward a lot interfering with the passenger pegs and with the axle mount it will push the tag bracket way out into space and look odd. In examining the bike, it seems that I would need the axle nut adapter from Top Down Products http://topdownproducts.com/html/axle_mount.html to do the axle mount set-up because of the recessed area of the swingarm in which the axle nut sits. Is this correct?
I am wanting to utilize one of the tag brackets from Road 6 Customs because of their simplicity and cost as compared to other options on the market.
Thanks for the help.
Old Oct 3, 2012 | 04:58 PM
jreichart's Avatar
jreichart
I just put my tag bracket on the right side of the bike. Problem solved.
Old Oct 3, 2012 | 05:32 PM
Midgard's Avatar
Midgard
Mine is an axle mount - that way it sits behind the swingarm bag (my swingarm bag is a LaRosa - dont buy it they are cheap quality - get one from Leatherworks)
here's a couple older pics if it helps -
Old Oct 3, 2012 | 07:04 PM
lupus's Avatar
lupus
I used a road6customs axle mount plate. It's vertical so it doesn't stick way out. Price was right also. I added the LED mounting bolts to illuminate.
Old Oct 3, 2012 | 07:45 PM
rockerz's Avatar
rockerz
I have top down plate with swing arm mount with my saddle bag mounted between the plate & passenger foot peg, fits perfect.
Old Oct 4, 2012 | 04:33 PM
Rock Southbrook
Thanks for the replies everyone.
I am liking the look of the axle mount the best, but am having a hard time parting with the money that Top Down wants for the Roto-plate. I may just get their axle mount and fab something myself... or hack up a Road 6 mount to my liking.
Old Oct 5, 2012 | 08:28 AM
JAFlanders's Avatar
JAFlanders
Default Left side License Plate Chopper Bag
The Leatherworks also makes a smaller Swingarm Bag that fits with a Left side License Plate. Check it out at:
http://www.sideroadcycles.com/Import...opper_Bag.html
Old Oct 5, 2012 | 01:04 PM
Zzzzz's Avatar
Zzzzz
Stage II
I'm looking to relocate the plate on my Slim. How are you guys dealing with spacing the taillights properly when the factory plate bracket is removed?
Old May 31, 2013 | 09:55 PM
forumpete's Avatar
forumpete
1st Gear
Sorry for bringing up such an old post. I'm tryin to do this exact mount on my night train. My problem is that the axle isn't long enough. When I install the mount there aren't enough threads left to properly install the crown nut. How did you make this work? Longer axle??
Thanks!
Old May 31, 2013 | 11:16 PM
Cygnusx51's Avatar
Cygnusx51
Hey Pete, I have the DK customs axel mount which looks pretty similar. Take off the thick washer, the mount should just replace that. Here's mine. And for the sake of this thread there's no problem with a swingarm bag fitting (Leatherworks)
