Shock adjustment for my 2013 Heritage
Old Oct 25, 2012 | 07:25 PM
t-bear's Avatar
t-bear
Default Shock adjustment for my 2013 Heritage
I have had my bike about 3 weeks now and I am going in for my 1,000 mile service next week.
One of the things I would like to do is have them adjust the shocks, it is currently set at 2 from the factory.
I weight about 200 lbs and my wife about 150, I will be riding solo most of the time but about 25% of the time with a passenger.
Looking at the service manual it seems I should set it to #4 335-395, when we are two up. I have always set my preload on all my bikes for the two up weight and then my ride was just a little stiffer.
Does this make sense?
The Service Manual states I need a special tool to adjust the shocks is this true?
Thanks for your help
Dan
Old Oct 25, 2012 | 08:16 PM
eleft's Avatar
eleft
I have a softail '07 FXSTC. I bought the HD wrench, the shocks can be adjusted using a strap wrench also. The entire shock rotates on the adjuster bolt. Holding the bolt from turning is necessary.
We ride 2 up and I adjusted the shocks equally out toward the lock nut 11/2 turns, it rides nice and rarely bottoms out.
Al
Old Oct 25, 2012 | 08:47 PM
TheTroupe's Avatar
TheTroupe
Dan
The shocks are not setup for 2 from the factory, they are at the softest setting possible from the factory.
Yes you will need a cheap little special wrench to actually adjust the shocks but breaking the lock nuts loose is a pain in the butt.
You will quickly discover that if you are going from 1 up to 2 up regularly you will want air shocks (Shotguns are the best and most costly). I ride solo 100% so progressive 422s are just fine for me.
Old Oct 25, 2012 | 08:52 PM
soft 02's Avatar
soft 02
If you dont want to get the HD tool use an oil filter strap wrench. https://www.google.com/search?q=oil+...w=1675&bih=933
Old Oct 26, 2012 | 07:02 AM
spydyr's Avatar
spydyr
Agree on all points--it is the softest from the factory, changing from 1 to 2 sucks (if you can do the air, I would), and the harley shock wrench really isn't that expensive, and will last a lifetime.
Personally, I would never pay anyone to turn a wrench a few times, especially not at ~$100 an hour!!!
Old Oct 26, 2012 | 07:06 AM
soft 02's Avatar
soft 02
Come on. Thats our bread and butter. Love those easy jobs and a one hour minimum...
Old Oct 26, 2012 | 08:54 AM
t-bear's Avatar
t-bear
The shop included the 1000 & 5000 service when i bought the bike, other wise i do all my own wrenching.
Since there will be no charge i figured i would have then do the work.
Old Oct 26, 2012 | 09:01 AM
oct1949's Avatar
oct1949
To keep U from buying the tool if U don't want too, Ur dealer should adjust Ur shocks at no charge at the 1k service. I did the very same to mine as Ur wanting to do.
I had them (dealer) adjust two things which they didn't charge me for at the 1K.
They did the shocks (too light) and passing lights (too low).
Old Oct 26, 2012 | 09:03 AM
spydyr's Avatar
spydyr
Sorry dude, the only thing I've had somebody else do to my bike is change the tires and change the stator under warranty. 50K miles and still purring like a lion!!
Old Oct 26, 2012 | 10:26 AM
Ramboamt's Avatar
Ramboamt
Default Shotgun Shock air shocks YEP that's the ticket
As mentioned earlier the Shotgun Shock air suspension is the way to go if you do two up riding because setting the bike at the stiffer setting is going to become a pain in your back, when riding and getting down on the floor and adjusting yourself. With the SS setup you can adjust on the fly and it also has the "WOW COOL" factor when you pull into a stop and other riders are around and you lower it down or raise it up.
Just my
