Ya I'm curious about this too. The harley site says to 2010. Did it just bolt on?
It appears it did... Worse case, buy the kit, test fit it...if it doesn't work, you return it. It comes with a plastic scratch preventing covering on the shield...as long as you don't pull that off, it's returnable.
IMO, this is the piece the bike should have come with from the factory...that plastic garbage they use is rediculous.
