Relocate speedometer/dash/ignition
Old Dec 19, 2012 | 09:03 PM
jreichart's Avatar
jreichart
Ill update with a thread soon, parts are arriving, and i should be finished the CAD design for the mount shortly. Going to make some prototype mock ups from plexi to make sure everything is where I want it to be, then send the drawings out to have it machined out of aluminum. I'll post pics along the way, hoping its a pretty straight forward project!
Old Dec 19, 2012 | 10:45 PM
honkylips's Avatar
honkylips
I used a blackline dash, filled in my fuel gauge hole, and relocated my ignition to right below the front of the left rear strut. I don't run a speedo.
Old Dec 20, 2012 | 06:23 AM
Fenres's Avatar
Fenres
No clutch either?
Old Dec 20, 2012 | 09:00 AM
rancid13's Avatar
rancid13
Originally Posted by Fenres
No clutch either?
I think I see a jockey shift right there.
Honkeylips: How long u been running no speedo? I've considered it but didnt know how hard it would be to get used to... Also, the dummy lights. I know I know you should be able to find nuetral without a light, but sometimes its not the easiest
Old Dec 21, 2012 | 11:16 PM
honkylips's Avatar
honkylips
Yup, jockey shift. I haven't had a speedo in a few years and don't miss it. You'd be surprised at how easy it is to gauge your speed (especially if there's traffic on the road). When I pass those radar speed limit signs that display your speed, I can always guess my speed within +/- 2mph. If you're on the highway with no traffic around, it can be tougher to gauge your speed, but other than that, no biggie.
I do have dummy lights. They are little LED lights on the back of the fork panel. In that pic, you can see two toggle switches (air ride switch and headlight lo/off/hi switch). Anyway, there are 3 small led lights next to those (oil, neutral, and check engine), they are just hard to see in that pic.
Old Dec 21, 2012 | 11:31 PM
micahpop's Avatar
micahpop
The speed is not that hard to judge. Mileage though, takes some more thought.
Old Dec 22, 2012 | 12:26 AM
Midgard's Avatar
Midgard
TIGHT
Old Dec 22, 2012 | 07:38 AM
rancid13's Avatar
rancid13
I see, where did you get the 3 LED setup? Just tryin to have a backup plan in case i cant re-use my current ones somehow
Old Dec 22, 2012 | 09:32 AM
Branner's Avatar
Branner
Fenres: I removed and trashed my dash, relocated my speedo and eliminated my fuel gauge/cap all together. I moved my ignition to where my horn was, bought a new speedo and relocated it to my rocker box. I then took my tank to a welder I know and he grinded the seam in the middle of the tank and filled in the gauge side. I know a guy who owns a collision shop and he took care of painting it for me. All said and done, the project cost $200 and three cases of beer.
Old Dec 22, 2012 | 12:02 PM
honkylips's Avatar
honkylips
I just bought some mini led lights such as these
http://m.summitracing.com/parts/upd-39316b/media
TUFF LUCK
Oct 22, 2018 01:43 PM
cvaria
Nov 24, 2015 04:05 PM
chevy454454
EVO
Jan 20, 2015 05:48 PM
SevieC
Oct 16, 2012 05:53 PM
boboridesthefa
Mar 17, 2011 04:44 PM
