No hissing sound when key is turned on
Old Jan 27, 2013 | 02:42 PM
Gorilla beetle's Avatar
Gorilla beetle
Stage II
Default No hissing sound when key is turned on
I recently took the tank and fenders off of my 04 heritage efi for paint, when i put it back together and put gas in it no sound when i turn the ignition on. It tries to crank but wont turn over. I reset the dash thinking that was the problem (i have no idea how to read the diagnostics) probably just a small problem. Im a painter not a mechanic. Any info would be appreciated
Old Jan 27, 2013 | 02:49 PM
TheTroupe's Avatar
TheTroupe
The hiss that you miss is the fuel pump not running.
Check wires - Check Fuses - etc...
Old Jan 27, 2013 | 03:11 PM
lupus's Avatar
lupus
Yep. Sounds like a wire, harness, etc. didn't make it back together properly. Make sure a harness pin didn't push out the back too. You never know...
Old Jan 27, 2013 | 03:27 PM
Gorilla beetle
Stage II
Thanks for the feedback, i think a harness pin may be the culprit, i was having trouble with the pins bending on the harness under the dash on the tank
Old Jan 27, 2013 | 06:40 PM
Chip Hazard's Avatar
Chip Hazard
Thats what happened,one of the pins bent
davehtutk
Feb 23, 2018 10:04 AM
BlockHead74
General Topics/Tech Tips
Jul 22, 2015 07:54 AM
Harleynoob
Electrical/Lighting/Alarm
May 27, 2015 05:12 AM
BikesFixCobwebBrain
Mar 28, 2015 07:30 PM
lostrider06
Nov 8, 2010 06:41 PM
